How to get started with SDIO on LPC4370?
annamol
I have been testing Gainspan modules and LPC4337 was used to interface with them through SDIO. Currently, for the final application, I'm trying to implement the gainspan module interfacing on a LPC4370 device (LPC Link2). I neither found any example codes for SDIO to get started with nor simply porting the board dependent libraries from LPC4337 to LPC4370 helped me. I am seeking some pointers to get this issue resolved. Thanks.
Hui_Ma
Customer need to check if the SDIO interface using the same pins.
For the LPC4370 chip using the same SD/MMC module with LPC4337 chip, the SDIO software without need  any modification.
Wish it helps.
Ma Hui
