How to disable WWDT while debugging in LPC55
1,557件の閲覧回数
jimmyli
Contributor V
      When our customer selected LPC550x MCU to develop, they found the wwdt will reset the mcu while debugging and the SWD doesn't work.
      Also, I find wwdt supporting debug mode, but can't find any way to disable wwdt while debugging.
     Can you help to check it?
     Thanks very much.
----below is a example to disable wwdt while debugging for ST mcu
STM32在DEBUG调试模式下禁止看门狗IWDG WWDG_梓默的博客-CSDN博客_stm32 关闭看门狗
1,548件の閲覧回数
xiangjun_rong
I suppose that you can disable WWDT when you develop/debug your application code with the code
SYSCON->AHBCLKCTRLX[0]|=1<<22;
WWDT->MOD&=~(0x01); //disable WWDT by clearing the WDEN bit in MOD reg
Hope it can help you
XiangJunRong
