How to change CTIMER PWM settings on MCUXpresso? (LPC802)
5,031 次查看
eddsanliik
Hello everyone,
I am using LPC802 processor to generate PWM signal.  I set CTIMER0 (PIO0_9) to 3kHz %50 duty PWM and also set 600Hz MRT Interrupt for GPIO toggle. But PWM start with low. How can i change it to start with high? I added my signal picture and my main code.
Thank you.
Eda
3 回复数
5,011 次查看
eddsanliik
is there any solution about starting with high level with LPC802?
4,987 次查看
Hello @eddsanliik
Sorry I don't think Ctimer PWM can.
Alice
5,017 次查看
Hello @eddsanliik
All single edge controlled PWM outputs go LOW at the beginning of each PWM cycle.
Alice
