How does LPC power profile API work?
yoshiyukiokada
I'm using LPC812.
I'd like to use power profile API, however, I couldn't  find any documents which describe about the power profile API in detail.
How can I know that  how does LPC power profile API work?
kerryzhou
Hi Yoshiyuki,
  Sorry for my later reply because of China's National Day and Mid-Autumn Festival.
  User manual already the detail documents, this document really didn't mentioned which register is affect. But I don't think it is the necessary. You just need to check whether the function result is correct.
kerry
yoshiyukiokada
Hi Kerry,
Thank you for your help. I had already read the UM101601, I understood that it is possible to control current consumption and performance using power profile API. The UM101601 however does not explain how the power API affects MCU's registers. Can I have any documents which explain about it.
best regards,
Yoshiyuki
kerryzhou
Hi Yoshiyuki,
kerry
kerryzhou
Hi Yoshiyuki,
   If you want to use the Power profile API ROM driver, you can refer to the LPC812 user manual:
https://www.nxp.com/docs/en/user-guide/UM10601.pdf
Page 297, there have the detail descriptions.
After you read the user manual, if you still have detail question, please let me know.
Kerry
