How can I produce a consistent SRAM PUF reading through multiple power cycles?
1,604件の閲覧回数
kgubbi
The LPC55S69-evk board I am using has the SRAM PUF feature. I am able to display the SRAM PUF readings on the terminal window. I get different PUF readings every time I power cycle the device. How do I get a device-unique and consistent SRAM PUF reading through power-cycles?
Also, If there is a PUF testing software, where can I download it from?
Thank You!
タグ(2)
1,548件の閲覧回数
ZhangJennie
I think this question is answered in case 00284026 as well.
If this is a different one, please let me know. Thank you.
Best Regards
Jun Zhang
