HOW TO TRANSMIT THE DATA USING UARTS IN LPC3250 IN LINUX PLATFORM AND CHECK WHETHER THE DATA IS TRANSMITTED OR NOT
879 次查看
Content originally posted in LPCWare by MOHAMMAD BIYABANI on Fri Apr 05 04:16:03 MST 2013
I am working on LPC3250 board with linux(3.0.10) ubuntu(11.10) version.Basically only one UART1 has been enabled for BOOTING <span class="skimwords-unlinked">Process.But,In</span> this board i want to send the data using remaining UARTS( i,e from board UARTS to another system or board). How can i transmit the data and test whether data is transmitted or not?<span class="skimwords-unlinked"></span>
Thanks &amp; Regards,
MOHAMMAD BIYABANI.
0 回复数
