Frequency modulation in LPC824
1,757 次查看
ranjithshanbhag
@Kerry Zhou
Hi Kerry,
Hope you are doing good.
I am using LPC824 controller. I am using COUNT_L and COUNT_H to generate 2 different PWM's. My Carrier Frequency is 100KHz and modulated frequency need to vary from 3K to 50K. but i am not able to move ahead from 14K. Please suggest me how to solve this ?
Please find the attachment for code.
Original Attachment has been moved to: PWM-code.txt.zip
标签 (1)
标记 (1)
2 回复数
1,610 次查看
kerryzhou
Hi Ranjith Shanbhag,
    I am good, hope you are fine too!
    Now confirm your question again, do you mean you can't get 14Khz PWM frequency with SCT?
    Please clarify it, then I will help you to calculate and test it.
Kerry
1,610 次查看
ranjithshanbhag
Hi Kerry,
i am also good!
During frequency modulation, modulated frequency i want to vary from 3KHz to 50KHz. I am increasing modulated frequency from 3KHz and able to reach till 14KHz. It is not increasing, once it is reached to 14KHz.
Hope you understood my problem.
