FlexIO equivalent on LPC55
4,086 次查看
dav1
Contributor V
Are there any equivalent ways of doing what flexio did on the kinetis range.
need to syncronize the DAC of an LPC55 to control a demux/S&H circuit to achieve say 16 outs or more.
Thx
标签 (3)
5 回复数
4,077 次查看
There is no DAC module of LPC55xx.
Alice
4,073 次查看
dav1
Contributor V
Strange, the datasheet says
2x 12-bit 1Msps DAC
1x 14-bit 5Msps DAC
Regardless, please reply the question on flexio vs achieving the same using SCT
4,059 次查看
Hello Dav1,
About the datasheet you mentioned, please share the part number of your chip, I will check .
About "the question on flexio vs achieving the same using SCT", please describe detail what function
 do you want to do with SCT.
Alice
4,048 次查看
dav1
Contributor V
please see my first post that describes the problem
4,024 次查看
frank_m
Senior Contributor III
An ADC is something quite different from a DAC.
To me it is not clear what that is supposed to mean, especially in the context of other vendor's peripheral connection mechanisms.
The ADC peripheral is extensively described in the MCU user manual, including trigger options (timer, external) and transfer options (DMA).
