Flash driver operation gave error
Sunil2
Dear sir,
We have purchased 5 board LPC54S018-EVK and testing be carried out UART communication, The flowing result observed. Looking for suggestion for problem resolution.
1.Unable to perform operation! Command failed with exit code 1
Miguel04
Hi @Sunil2
Could you provide more information, please?
Are you using an SDK example?
With what are you trying to communicate the LPC?
I'll be waiting for your response.
Best Regards, Miguel.
Sunil2
Hi @Miguel04 ,
Thank you for your replay.
Yes we are using SDK example, example name: usart_dma_rb_transfer.c , not for this example I tried other example also but same problem.
LPC name:54S018JET180
Miguel04
Hi @Sunil2
Could you help me looking into this link, please? This is a Getting Started guide for the LPC54S018.
Let me know if this help you.
Sunil2
Hi @Miguel04
Thank you for your feedback.
We are try to buy 2 more 54S018 EVK with RK043FN02H-CT, But that type of EVK  and display both are not available right now, So  Please suggest alternate part number of RK043FN02H-CT display.
Miguel04
Hi @Sunil2
Look at the RK043FN66HS-CTG, this could be a alternative. Let me know if you have another question.
