Failure in LPC1768 erasing and programming
lpcware
Content originally posted in LPCWare by Adibsp on Mon Jul 08 05:55:07 MST 2013
<h3 class="groups title" style="margin: 0px; padding: 0px; border: 0px; outline: 0px; font-weight: inherit; font-size: 16px; font-family: Arial, sans-serif; vertical-align: baseline; color: #333333;">Hello Does anybody know about how I can erase my LPC1768 core after that my downloaded program on it leads to problem of Cortex-M identification by KEIL?</h3>
<p class="summary" style="margin: 0px; padding: 0px; border: 0px; outline: 0px; font-size: 13px; font-family: Arial, sans-serif; vertical-align: baseline;">I use Jlink and tried SEGGER to erase but it failed!
once I used Flash magic to serial programming but didn't succeed.
lpcware
Content originally posted in LPCWare by Wouter on Mon Jul 08 06:59:48 MST 2013
You should be able to erase/reprogram the chip when booting into ISP mode: Pull pin P2.10 (ISP) low during reset. The device now boots into ISP mode, and does not boot the application. You should now be able to erase or reprogram the chip using either JTAG, SWD or ISP.
Wouter
