Fail to transmit and receive extended id frame of CAN
784 次查看
lpcware
Content originally posted in LPCWare by sk.danish on Sun Mar 06 21:21:12 MST 2016
I have written two sample code using lpcopen libray. One is for transmission and another is for reception.
But i was unable to transmit and receive extended id frame. The same code is working fine is i am using STD. id frame.
I am just stuck with this problem kindly tell me how to initialize can controller for extended id frame.
Thanks in advance.
762 次查看
lpcware
bump
