Example "LPCX176x_cmsis2_EasyWeb" does not work?
lpcware
Content originally posted in LPCWare by kevin on Wed Mar 27 05:48:03 MST 2013
I'm using the example program "LPCX176x_cmsis2_EasyWeb." I'm trying to test the Ethernet communication using the command "ping" however nothing happens.
I just set the IP and Ethernet gateway, need to change anything else in the program code?
