In this project an acceptance filter is set to identifier 0x100 and the interrupt filter is handling status interrupts and error interrupts. When I am sending messages with other identifiers, I get an status interupt with status CCAN_STAT_RXOK. But the message I cannot read. When I remove status interrupt from my interrupt filter I get only interrupts for the identifier 0x100, what I expect.
1) Is there any way to get the message of identifier, which are not defined in a filter?
-> status interrupt CCAN_STAT_RXOK -> read message from other identifier
2) How I can get every message received from the CAN-bus (no filter)
已解决! 转到解答。
Hi Andreas Kneissl,
You can configure the can in the test mode, and enable the basic mode.
Please modify the code like this:
CCAN_MSG_OBJ_T can_msg;
void CAN0_IRQHandler(void)
CCAN_MSG_OBJ_T msg_buf;
uint32_t can_int, can_stat, i;
while ( (can_int = Chip_CCAN_GetIntID(LPC_C_CAN0)) != 0 ) {
//if ((can_int & CCAN_INT_STATUS) )
if ((CCAN_INT_STATUS == can_int) && (CCAN_STAT_RXOK & LPC_C_CAN0->STAT))
//CCAN_MSG_OBJ_T can_msg;
can_msg.id = (uint32_t) (LPC_C_CAN0->IF[1].ARB1 | LPC_C_CAN0->IF[1].ARB2 << 16);
if (can_msg.id & (0x1 << 30)){
can_msg.id &= CCAN_MSG_ID_EXT_MASK;
else {
can_msg.id >>= 18;
can_msg.id &= CCAN_MSG_ID_STD_MASK;
can_msg.dlc = (uint8_t) (LPC_C_CAN0->IF[1].MCTRL & CCAN_IF_MCTRL_DLC_MSK);
*((uint16_t *)&can_msg.data[0]) = (uint16_t) (LPC_C_CAN0->IF[1].DA1 & 0x0000FFFF);
*((uint16_t *)&can_msg.data[2]) = (uint16_t) (LPC_C_CAN0->IF[1].DA2 & 0x0000FFFF);
*((uint16_t *)&can_msg.data[4]) = (uint16_t) (LPC_C_CAN0->IF[1].DB1 & 0x0000FFFF);
*((uint16_t *)&can_msg.data[6]) = (uint16_t) (LPC_C_CAN0->IF[1].DB2 & 0x0000FFFF);
DEBUGOUT("can_msg ID :%x\r\n", can_msg.id);
DEBUGOUT("can_msg data :");
for (i = 0; i < can_msg.dlc; i++) {
DEBUGOUT("%x ", can_msg.data[i]);
DEBUGOUT("\r\nFeed back...\r\n");
Rx_Flag =1;
LPC_C_CAN0->STAT = LPC_C_CAN0->STAT & (~CCAN_STAT_RXOK);
return;
int main(void)
CCAN_MSG_OBJ_T send_obj;
SystemCoreClockUpdate();
Board_Init();
set_pinmux();
DEBUGOUT(WelcomeMenu);
/* Set CCAN peripheral clock under 100Mhz for working stable */
Chip_Clock_SetBaseClock(CLK_BASE_APB3, CLKIN_IDIVC, true, false);
Chip_CCAN_Init(LPC_C_CAN0);
Chip_CCAN_EnableTestMode(LPC_C_CAN0);//jjadd
// Chip_CCAN_ConfigTestMode(LPC_C_CAN0, ( CCAN_TEST_BASIC_MODE));//jjadd //CCAN_TEST_SILENT_MODE |
Chip_CCAN_SetBitRate(LPC_C_CAN0, 500000);
Chip_CCAN_EnableInt(LPC_C_CAN0, (CCAN_CTRL_IE | CCAN_CTRL_SIE | CCAN_CTRL_EIE));
send_obj.id = CCAN_TX_MSG_ID;
send_obj.dlc = 4;
send_obj.data[0] = 'A';
send_obj.data[1] = 'B';
send_obj.data[2] = 'C';
send_obj.data[3] = 'D';
Chip_CCAN_Send(LPC_C_CAN0, CCAN_MSG_IF1, false, &send_obj);
Chip_CCAN_ClearStatus(LPC_C_CAN0, CCAN_STAT_TXOK);
NVIC_EnableIRQ(C_CAN0_IRQn);
while (1) {
After modify like the above code, I can receive all the IDs.
The test result is:
Wish it helps you!
If you still have question, please let me know!
Kerry
Hi Andreas Kneissl,
else {
can_msg.id >>= 18;
Rx_Flag =1;
return;
int main(void)
Board_Init();
set_pinmux();
send_obj.dlc = 4;
while (1) {
The test result is:
Wish it helps you!
Kerry
