ECDA signature verification with CASPER
s_hdl
Spoiler
I managed to build mbedTLS on my own, in order to verify a signature with ECDSA (MBEDTLS_ECP_DP_SECP256R1).
With no alt implementation (all computation done by the CPU), the signature verification takes up to 4 seconds to compute on the LPC55S06.
I'm trying now to link mbedTLS ecdsa_verify() function with CASPER fsl driver. But it's not clear to me as the ECDSA verification doens't seem to be a single operation.
How to link the basic primitive of CAPSER (SECP256R1_Mul & SECP256R1_MulAdd) with the mbedTLS function ECDSA_verify() ?
Thank you in advance for your replie.
Harry_Zhang
Hi @s_hdl
ECDSA verification consists of several arithmetic and elliptic-curve operations, so it does not map to a single CASPER primitive.
In the MCUXpresso SDK, the integration is already implemented in the CASPER PSA Crypto port. The casper_mbedtls_ecdsa_verify() function performs the standard ECDSA verification flow, including the calculation of u1 and u2. It then calls:
casper_mbedtls_ecp_muladd(grp, &R, u1, &grp->G, u2, Q);
to calculate:
R = u1 × G + u2 × Q
The ECP adaptation layer converts the mbedTLS MPI values and elliptic-curve points into the format required by CASPER and maps this operation to CASPER_ECC_SECP256R1_MulAdd().
Similarly, casper_mbedtls_ecp_mul() maps a single scalar multiplication to CASPER_ECC_SECP256R1_Mul().
Therefore, rather than modifying mbedtls_ecdsa_verify() directly, we recommend reusing the complete CASPER integration provided by the SDK under:
component/psa_crypto_driver/casper_driver
In particular, please refer to:
mcux_psa_casper_ecdsa_port.c
mcux_psa_casper_ecp_port.c
Since you built mbedTLS separately, please also make sure that your mbedTLS version is compatible with the MCUXpresso SDK CASPER port.
You can refer to the lpcxpresso55s06_psa_crypto_examples.
Harry
peter89jean
You generally don’t need to replace mbedtls_ecdsa_verify() itself; the CASPER acceleration should be integrated at the elliptic-curve/multiplication layer that mbedTLS uses internally. ECDSA verification requires computing scalar multiplications and their sum, so SECP256R1_Mul() can handle the individual scalar-point multiplication while SECP256R1_MulAdd() can accelerate the combined operation. The exact integration depends on your mbedTLS version and NXP CASPER driver API, but the usual approach is to provide an mbedTLS alternative/optimized implementation for the P-256 scalar-multiplication primitives rather than calling CASPER directly from ecdsa_verify().
s_hdl
Hello peter89jean,
Thank you for your reply. The approach you mention is what I had in mind but there doesn't seem to be simple and straightforward SECP256R1_MULADD_ALT or SECP256R1_MUL_ALT defines in the mbedTLS config file. Maybe I should ask this question to a more mbdedTLS dedicated forum.
Thanks again.
Regards.
Harry_Zhang
Hi @s_hdl
to calculate:
R = u1 × G + u2 × Q
Harry
s_hdl
Hello Harry,
Your answer helped me a lot, thank you. Everything works fine using the CASPER implementation now.
Regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-2411077%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EECDA%20signature%20verification%20with%20CASPER%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411077%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ESpoiler%3C%2FA%3E%3CNOSCRIPT%3E%20(Highlight%20to%20read)%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3E%26nbsp%3B%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3EHello%2C%3CBR%20%2F%3EI%20managed%20to%20build%20mbedTLS%20on%20my%20own%2C%20in%20order%20to%20verify%20a%20signature%20with%20ECDSA%20(MBEDTLS_ECP_DP_SECP256R1).%3CBR%20%2F%3EWith%20no%20alt%20implementation%20(all%20computation%20done%20by%20the%20CPU)%2C%20the%20signature%20verification%20takes%20up%20to%204%20seconds%20to%20compute%20on%20the%20LPC55S06.%3CBR%20%2F%3E%3CBR%20%2F%3EI'm%20trying%20now%20to%20link%20mbedTLS%20ecdsa_verify()%20function%20with%20CASPER%20fsl%20driver.%20But%20it's%20not%20clear%20to%20me%20as%20the%20ECDSA%20verification%20doens't%20seem%20to%20be%20a%20single%20operation.%26nbsp%3B%3CBR%20%2F%3EHow%20to%20link%20the%20basic%20primitive%20of%20CAPSER%20(SECP256R1_Mul%20%26amp%3B%20SECP256R1_MulAdd)%20with%20the%20mbedTLS%20function%20ECDSA_verify()%20%3F%3CBR%20%2F%3E%3CBR%20%2F%3EThank%20you%20in%20advance%20for%20your%20replie.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2411077%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC55xx%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ECDA%20signature%20verification%20with%20CASPER%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20peter89jean%2C%3CBR%20%2F%3E%3CBR%20%2F%3EThank%20you%20for%20your%20reply.%20The%20approach%20you%20mention%20is%20what%20I%20had%20in%20mind%20but%20there%20doesn't%20seem%20to%20be%20simple%20and%20straightforward%20SECP256R1_MULADD%3CSTRONG%3E_ALT%3C%2FSTRONG%3E%20or%20SECP256R1_MUL%3CSTRONG%3E_ALT%26nbsp%3B%3C%2FSTRONG%3Edefines%20in%20the%20mbedTLS%20config%20file.%20Maybe%20I%20should%20ask%20this%20question%20to%20a%20more%20mbdedTLS%20dedicated%20forum.%26nbsp%3B%3C%2FP%3E%3CP%3EThanks%20again.%3CBR%20%2F%3E%3CBR%20%2F%3ERegards.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ECDA%20signature%20verification%20with%20CASPER%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYou%20generally%20don%E2%80%99t%20need%20to%20replace%20mbedtls_ecdsa_verify()%20itself%3B%20the%20CASPER%20acceleration%20should%20be%20integrated%20at%20the%20elliptic-curve%2Fmultiplication%20layer%20that%20mbedTLS%20uses%20internally.%20ECDSA%20verification%20requires%20computing%20scalar%20multiplications%20and%20their%20sum%2C%20so%20SECP256R1_Mul()%20can%20handle%20the%20individual%20scalar-point%20multiplication%20while%20SECP256R1_MulAdd()%20can%20accelerate%20the%20combined%20operation.%20The%20exact%20integration%20depends%20on%20your%20mbedTLS%20version%20and%20NXP%20CASPER%20driver%20API%2C%20but%20the%20usual%20approach%20is%20to%20provide%20an%20mbedTLS%20alternative%2Foptimized%20implementation%20for%20the%20P-256%20scalar-multiplication%20primitives%20rather%20than%20calling%20CASPER%20directly%20from%20ecdsa_verify().%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20ECDA%20signature%20verification%20with%20CASPER%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F266219%22%20target%3D%22_blank%22%3E%40s_hdl%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EECDSA%20verification%20consists%20of%20several%20arithmetic%20and%20elliptic-curve%20operations%2C%20so%20it%20does%20not%20map%20to%20a%20single%20CASPER%20primitive.%3C%2FP%3E%0A%3CP%3EIn%20the%20MCUXpresso%20SDK%2C%20the%20integration%20is%20already%20implemented%20in%20the%20CASPER%20PSA%20Crypto%20port.%20The%20casper_mbedtls_ecdsa_verify()%20function%20performs%20the%20standard%20ECDSA%20verification%20flow%2C%20including%20the%20calculation%20of%20u1%20and%20u2.%20It%20then%20calls%3A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Ecasper_mbedtls_ecp_muladd(grp%2C%20%26amp%3BR%2C%20u1%2C%20%26amp%3Bgrp-%26gt%3BG%2C%20u2%2C%20Q)%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CDIV%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Eto%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Ecalculate%3A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3ER%20%3D%20u1%20%C3%97%20G%20%2B%20u2%20%C3%97%20Q%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CDIV%3E%0A%3CP%3EThe%20ECP%20adaptation%20layer%20converts%20the%20mbedTLS%20MPI%20values%20and%20elliptic-curve%20points%20into%20the%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Eformat%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Erequired%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Eby%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3ECASPER%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Eand%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Emaps%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Ethis%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Eoperation%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Eto%3C%2FSPAN%3E%20%3CCODE%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3ECASPER_ECC_SECP256R1_MulAdd()%3C%2FSPAN%3E%3C%2FCODE%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3ESimilarly%2C%3C%2FSPAN%3E%20%3CCODE%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Ecasper_mbedtls_ecp_mul()%3C%2FSPAN%3E%3C%2FCODE%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Emaps%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Ea%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Esingle%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Escalar%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Emultiplication%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Eto%3C%2FSPAN%3E%20%3CCODE%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3ECASPER_ECC_SECP256R1_Mul()%3C%2FSPAN%3E%3C%2FCODE%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3E.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3ETherefore%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Erather%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Ethan%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Emodifying%3C%2FSPAN%3E%20%3CCODE%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Embedtls_ecdsa_verify()%3C%2FSPAN%3E%3C%2FCODE%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Edirectly%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Ewe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Erecommend%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Ereusing%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Ethe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Ecomplete%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3ECASPER%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Eintegration%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Eprovided%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Eby%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Ethe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3ESDK%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Eunder%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Ecomponent%2Fpsa_crypto_driver%2Fcasper_driver%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CDIV%3E%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3EIn%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Eparticular%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Eplease%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Erefer%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22___1cs5bdp%20f1w7gpdv%20f5p0z4x%22%3Eto%3A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Emcux_psa_casper_ecdsa_port.c%0Amcux_psa_casper_ecp_port.c%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3ESince%20you%20built%20mbedTLS%20separately%2C%20please%20also%20make%20sure%20that%20your%20mbedTLS%20version%20is%20compatible%20with%20the%20MCUXpresso%20SDK%20CASPER%20port.%3C%2FP%3E%0A%3CP%3EYou%20can%20refer%20to%20the%26nbsp%3Blpcxpresso55s06_psa_crypto_examples.%3C%2FP%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1788493275769.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1788493275769.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1788493275769.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395899i1B18FB8ED74F1966%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1788493275769.png%22%20alt%3D%22Harry_Zhang_0-1788493275769.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHarry_Zhang_0-1788493275769.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHarry_Zhang_0-1788493275769.png%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EHarry%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411357%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20ECDA%20signature%20verification%20with%20CASPER%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411357%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Harry%2C%3CBR%20%2F%3E%3CBR%20%2F%3EYour%20answer%20helped%20me%20a%20lot%2C%20thank%20you.%20Everything%20works%20fine%20using%20the%20CASPER%20implementation%20now.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ERegards.%3C%2FP%3E%3C%2FLINGO-BODY%3E
