EA LPC1788 OEM
EA LPC1788 OEM
Content originally posted in LPCWare by Harvey_13 on Fri Dec 14 02:11:47 MST 2012
I wanted to compile the NXPUSBLib BSP library for the Embedded Electronic LPC1788 Board.
I got errors because the compiler could not find SystemCoreClock variable on the Audio_Init() function.
I removed this part to continue my tests, but I wonder if some files were missing on this library?
Maybe someone already has got this problem!
