Documentation Error
Documentation Error
lpcware
Content originally posted in LPCWare by rlund on Thu Nov 19 12:39:55 MST 2015
There is an error in both the 18xx user manual on page 260, and in the 18xx datasheet on page 43.  Both documents are describing pin multiplexing, and under the description for PD_3, the CTOUT_6 signal is described as "SCT output 7".  I believe this should say "SCT output 6".
lpcware
Content originally posted in LPCWare by lpcmunich on Fri Nov 20 06:40:50 MST 2015
Hi rlund,
You are absolutely right, these are typos in both these documents.
Will get those fixed in the new release.
Sorry for the inconvenience caused.
