Debug problem with LPC1830 and JLink GDB server
prashantkore
I am using LPC1830 for my development purpose with GCC's client GDB and Jlink GDB V6.62 application as GDB server. I am getting a lot of problems while debugging, where the program's main() never hits at the start of debug session, a lot of times the breakpoints just doesn't hit, in the middle of the debugging session suddenly the debug session ends abruptly. Can you please recommend the tools and version number of those tools which you've used for LPC1830 for smoother debug experience?
Alexis_A
Hello Prashant,
Can you let me know which IDE are you using?
Alexis Andalon
prashantkore
I have tried to use LPCExpresso IDE v8.2.2 and eclipse IDE 2020-06, both yield me the same result.
converse
Senior Contributor V
Use MCUXpresso 11.2.0. And let MCUXpresso auto-create your debug script (press the Blue debug button/Read the User guide!).
