Debug LPC1754 board
Debug LPC1754 board
4,498 次查看
YANHAI
I want debug LPC1754 using LPC-LINK2, However, It seems that LPC-LINK2 could not be purchased now.
I want know what new Dev board I can use?
I'm  new in this field, Thanks in advance!
9 回复数
4,477 次查看
YANHAI
Dear Jun Zhang
Thanks very much!
But when I check the Supported Devices page, LPC17xx is not listed.
So, I don't know if I can use it or not, is it no problem to use?
Thanks again!
Yanhai
4,463 次查看
ZhangJennie
I don't have LPC1754 but I ever used MCU-Link debugging LPC1769. it works well.
I believe MCU-Link work for LPC1754 as well.
4,456 次查看
YANHAI
Thanks Zhang Jennie, Ok, I will purchase a MCU-LINK and have a try then.
4,423 次查看
ZhangJennie
welcome!
4,347 次查看
YANHAI
Just let you know; it works perfect using MCU-Link to debug LPC1754.
Thanks very much!
4,343 次查看
ZhangJennie
Good to know. Thanks.
4,473 次查看
ErichStyger
Specialist I
I don't have that LPC1754, but it is listed as supported device in MCUXpresso IDE:
So I assume you can use the MCU-Link for it, as it is supported inside the IDE.
And if you are checking out debug probes: be sure to have a look at the Pro version too:
https://mcuoneclipse.com/2021/10/17/new-mcu-link-pro-debug-probe-with-energy-measurement/
It was for some time out of stock, but should be available again now.
I hope this helps,
Erich
4,455 次查看
YANHAI
Thanks EricStyger!
4,480 次查看
ZhangJennie
Hi @YANHAI
LPC-Link2 is no longer recommended. Please use MCU-Link. It supports LPC17xx
https://www.nxp.com/design/microcontrollers-developer-resources/mcu-link-debug-probe:MCU-LINK
Jun Zhang
