Dead forum
Dead forum
lpcware
Content originally posted in LPCWare by taker on Fri Oct 03 01:33:55 MST 2014
Dead forum
lpcware
Content originally posted in LPCWare by mch0 on Fri Oct 03 09:28:21 MST 2014
I second this.
Read that post because I also use the GPDMA and thought I might help.
But stopped when I saw that no effort had been made to explain why the chip driver of LPCOpen had not been used for something that looks like a standard case.
Waste of time on both sides.
Mike
lpcware
Content originally posted in LPCWare by TheFallGuy on Fri Oct 03 02:37:55 MST 2014
Maybe you didn't get a response because you didn't provide anything like enough information in your DMA post (and it is only 20 hours old, anyway).
If you want help, explain what the problem is
- what is your exact target. Is it a custom board, or one that you have purchased?
- what is not working. How do you know it is not working?
- what have you tried, and what were the results?
- have you read the user manual. what did that tell you?
- have you tried the code provided in LPCOpen?
We can only answer your questions if you provide enough information to help you. "It doesn't work" is not
