DFUSEC for LPC1830 Boot Pin
838件の閲覧回数
kensu
Contributor V
I am using LPC1830, I need to download firmware with DFUSEC tool ,I confirm with FAE,
The method is :
Step 1: Change boot source pin to (P2_9, P2_8, P1_2, P1_1,) (Low, High, Low, High) for boot from USB0.
Step 2: Use DFUSEC to upgrade firmware into QSPI Flash.
Step 3: Change boot source pin to (P2_9, P2_8, P1_2, P1_1,) (Low, Low, Low, High) for boot from QSPI.
Step 4: LPC1830 will boot from QSPI and execute updated application.
I want to know if good method that I don't need to change to boot source pin for DFUSEC download ?
Ken
4 返答(返信)
663件の閲覧回数
kensu
Contributor V
Dears
Thanks for your reply.
I want to confirm one thing for DFUSEC use.
If I let the boot pin become a button.
Press button will let boot pin become  (P2_9, P2_8, P1_2, P1_1,) (Low, High, Low, High)
Release button will let boot pin become  (P2_9, P2_8, P1_2, P1_1,) (Low, Low, Low, High)
Step 1:  Before POWER ON, press the button.
Step 2:  POWER ON, and start the DFUSEC flash download.
Step 3:  When DFUSEC start download, the user release the boot pin button, the DFUSEC will still download because it may take few seconds to minutes.
Step 4: After Download complete, Power Reset, and it will boot on QSPI.
Is my understanding correct?
During the DFUSEC downloading from USB0, can I change the boot pin High/Low status?
Ken
663件の閲覧回数
lpcxpresso_supp
Hi Ken,
Yes, your understanding is correct.
The boot pins are sampled at boot by the BootROM code. Once a boot has occurred they can be changed without effect on the target until the target is re-booted.
Yours,
LPCXpresso Support
663件の閲覧回数
kensu
Contributor V
I understood.
Ken
663件の閲覧回数
lpcxpresso_supp
Hi Ken,
The recommended way to program SPIFI flash is via LPCScrypt.
LPCScrypt v1.8.0|NXP
This tool like DFUSEC boots from USB so the boot source needs changing as you describe in order to set a board to boot from SPIFI flash.
An alternative would be to use a debug probe connection and program flash via SWD/JTAG.
If you take a look at MCUXpresso IDE - you will see that this provides a mechanism to program flash via the command line using a debug probe such as LPC-Link2.
Yours,
LPCXpresso Support
