DEBUGOUT give an "make ***[prj.axf] Error 1"
1,025 次查看
jespermadsen
I'm trying to use nxp_lpcxpresso_11c24_board_lib DEBUGOUT in my own project.
But I get an "make ***[prj.axf] Error 1" error.
I can see that the board_lib uses original Redlib semihosting with __write and __readc insted of __sys_write and __sys_readc.
Could this be the problem and how can I solve this?
标签 (2)
924 次查看
jespermadsen
I think I solved the problem..
It was becouse I managed the linker script myself.. because I use a flashpage as emulated eeprom.
And I there for I overlooked the option to build against RedLib(nohost).
924 次查看
kerryzhou
Hello Jesper Maden,
    Thank you for your solutions sharing.
     If you still have question in the next time, just create the post and let us know.
Kerry
