Configuring pin groups & functions
2,080件の閲覧回数
lpcware
Content originally posted in LPCWare by peterrq on Thu Oct 02 03:45:17 MST 2014
I am new to the LPC43xx series.
The device allows an excellent level of configuration; UARTs may be moved from one port pin to another.
Is there an application which may be used to generate the pin configurations used within board_sysinit.c ?
3 返答(返信)
2,064件の閲覧回数
lpcware
Content originally posted in LPCWare by nerd herd on Fri Oct 03 16:08:00 MST 2014
Hi peterrq,
Here is a link to our Pin Mux tool which is the closest thing we have that you are describing. Hope this helps.
http://www.lpcware.com/content/nxpfile/lpc43xx-pin-mux-tool
2,064件の閲覧回数
lpcware
Content originally posted in LPCWare by peterrq on Fri Oct 03 09:17:07 MST 2014
A program which I interact with and select functions. Pins show that they are allocated, list of options reduces. Program produces a 'C' file which would go in board_sysinit.c.
Something that simplifies the process.
I can do it but its hard, error prone work.
Back in the day Intel would release applications to figure out your registers settings, thats the sort of thing.
2,064件の閲覧回数
lpcware
Content originally posted in LPCWare by nerd herd on Fri Oct 03 08:28:00 MST 2014
Hi peterrq,
I'm glad you find the LPC43xx pin configuration excellent. I am unsure as to what you are asking, however. If you would like some help in configuring your own custom pin configuration, I'd be happy to help you. :)
A great reference would be the LPC43xx user's manual which can be viewed here:
http://www.nxp.com/documents/user_manual/UM10503.pdf
