Can a glitch filtered GPIO wake up a device from power down mode?
1,716 次查看
lpcware
Content originally posted in LPCWare by UncleJoe on Wed Jun 04 04:45:27 MST 2014
I've found when I recently turned on the GPIO glitch filter for my application, I can no longer press the button to wake up from power down mode.
Is this expected? Is it because the IOCON clock running the glitch filter is off during power down mode?
标签 (1)
2 回复数
1,663 次查看
lpcware
Content originally posted in LPCWare by UncleJoe on Thu Jun 05 00:31:44 MST 2014
OK, I can wake up the device now after disabling glitch filtering right before power down.
I think you should write about this nuance in the documentation.
1,663 次查看
lpcware
Content originally posted in LPCWare by nxp_apps on Wed Jun 04 16:59:06 MST 2014
If you have the glitch filter turned on in the IOCON before entering power-down mode, the IOCON will retain state when in power-down mode.
I would suggest to turn off the glitch filter before going into power-down mode.
Thanks.
nxp_support
