Brown Out detection Levels in LPC11U68
1,468 次查看
richardsoennich
I cannot find the actual BOD voltage levels in UM10732 or the datasheet.  Where are the listed?
Rich
1,358 次查看
victorjimenez
Hello Richard,
Please refer the 32-bit ARM Cortex-M0+ microcontroller datasheet: https://www.nxp.com/docs/en/data-sheet/LPC11U6X.pdf
In page 70 you will find the table with the voltage levels of the BOD.
Hope it helps!
Victor.
