Assertion fail when building for lpc2478
1,264件の閲覧回数
lpcware
Content originally posted in LPCWare by baot on Wed Sep 16 04:35:41 MST 2015
When changing build settings in LPCXpresso I receive a lot of error messages like the following:
c:/nxp/lpcxpresso_7.9.0_455/lpcxpresso/tools/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld.exe: BFD (GNU Tools for ARM Embedded Processors) 2.24.0.20150604 assertion fail /home/build/work/GCC-4-9-build/src/binutils/bfd/elf32-arm.c:7696
It doesn't matter what kind of changes to settings I apply, leading me to suspect a bug in LPCXpresso?
LPCXpresso v7.9.0 is being used
1,205件の閲覧回数
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Wed Sep 16 12:28:00 MST 2015
In order to assist, we need to preferably see a buildable project that shows up the problme, or at least see the link line from your build log:
[list]
  [*]https://www.lpcware.com/content/faq/lpcxpresso/how-importexport-projects
  [*]https://www.lpcware.com/content/faq/lpcxpresso/build-console
[/list]
It would also help to know exactly what build settings you changed that triggered the problem.
LPCXpresso Support
