Another PIN function question
lpcware
Content originally posted in LPCWare by tvink on Thu Dec 18 09:52:35 MST 2014
In UM10430 SD_LED is listed as a SD/MMC pin function.
This function is not found anywhere else in the document.  What pin is it?
lpcware
Content originally posted in LPCWare by tvink on Tue Jan 06 07:05:57 MST 2015
When I am just learning a new processor I try to avoid going deep for the first couple of passes, so naming details become more important to me at that time.
Fortunately your pin mapping Java app is very well done and answered all of my questions of this type.  And I was able to get all the functionality needed within the
pin constraints.
lpcware
Content originally posted in LPCWare by nerd herd on Mon Jan 05 11:45:37 MST 2015
Hi tvink,
Like in your other topic, this SD_LED is most likely an artifact of user manual revisions. Is the correctly documented SD pins sufficient for your project?
