MCUXPresso IDE SWO Trace function
The MCUXpresso IDE SWO trace function is a special feature which enables user to observe variable update, interrupt entry/exit timing, interrupt event statistic, to print information in SWO ITM Console while the MCU is running. The MCUXpresso IDE SWO trace function is a supplement to the debugger of the MCUXpresso IDE. The main advantage is to display variable, print information, list interrupt entrying/exitting/returing while the MCU is running.
 The documentation describes the hardware connection to implement the SWO function, MCUXpresso configuration and source code to implement the function.
%3CLINGO-SUB%20id%3D%22lingo-sub-1120001%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCUXPresso%20IDE%20SWO%20Trace%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120001%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EThe%20MCUXpresso%20IDE%20SWO%20trace%20function%20is%20a%20special%20feature%20which%20enables%20user%20to%20observe%20variable%20update%2C%20interrupt%20entry%2Fexit%20timing%2C%20interrupt%20event%20statistic%2C%20to%20print%20information%20in%20SWO%20ITM%20Console%20while%20the%20MCU%20is%20running.%20The%20MCUXpresso%20IDE%20SWO%20trace%20function%20is%20a%20supplement%20to%20the%20debugger%20of%20the%20MCUXpresso%20IDE.%20The%20main%20advantage%20is%20to%20display%20variable%2C%20print%20information%2C%20list%20interrupt%20entrying%2Fexitting%2Freturing%20while%20the%20MCU%20is%20running.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3EThe%20documentation%20describes%20the%20hardware%20connection%20to%20implement%20the%20SWO%20function%2C%20MCUXpresso%20configuration%20and%20source%20code%20to%20implement%20the%20function.%26nbsp%3B%20%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎06-05-2019 10:36 PM
Updated by:
