udp_echo
udp_echo
maheshwarreddy
Fresh Out Contributor
hi,
iam using the udo_echo in sdk2.0 but the processor(k66) is not giving output, iam using the clock at EXTAL pin and i changed the clock configuration to EXTAL . even though udp_echo is working .(iam using the k66 and phy LAN 8710).
Tags (3)
xiangjun_rong
I am not clear about your issue. If you use lwip_udpecho example code, the default PHY is KSZ8081 at least for FRDM-K64, if you use LAN 8710, I suppose you have rewrire the fsl_phy.c.
Can you describes your question in detail?
Xiangjun Rong
maheshwarreddy
hi,
iam not getting what are the changes i needs to make in the fsl_phy.c file, can you please help us.
maheshwarreddy
hi,
I want a little clarification on how use the udp echo (when I make a full run if I observe on the wire shark nothing is vailable and when see the register set of the Ethernet it is updating correctly) but the data is coming out.
