lwip freeRTOS ping demo with KDS 3.0 compile errors
已解决
跳至解决方案
2,851 次查看
pablofonovich
Hi:
I want to compile the ping demo with freeRTOS in my FRDM-K64F with KDS in release mode, but i get the errors "no rule to make target all" and "target all not remade because of errors". I don't know what this means. Someone knows what i'm missing here?
Thanks!
标签 (1)
1 解答
2,464 次查看
Carlos_Musich
Hi Pablo,
you need to generate libksdk_platform_freertos.a release target.
Please import ksdk_freertos_lib, right click on the project and select Build Configurations > Set Active > Release. This will generate C:\Freescale\KSDK_1.2.0\lib\ksdk_freertos_lib\kds\K64F12\release\libksdk_platform_freertos.a which is required by the application building with release target,
Carlos
在原帖中查看解决方案
3 回复数
2,464 次查看
Carlos_Musich
Hi Pablo,
I imported and build the project successfully. Did you made any change to the project (code, C/C++ settings, moved/removed files)? Do you see in the console output what file/path is missing?
If not please try cleaning and rebuilding the project.
Carlos
2,464 次查看
pablofonovich
Hi: Thanks for your reply...
I think the problem is that it can't find the library libksdk_platform_freertos.a, because the first complete error is:
make: *** No rule to make target `/home/pablo/Documentos/Documentacion/Freescale/KSDK_1.2.0/examples/frdmk64f/demo_apps/lwip/lwip_ping_demo/ping_rtos/ping_freertos/kds/../../../../../../../../lib/ksdk_freertos_lib/kds/K64F12/release/libksdk_platform_freertos.a', needed by `lwip_ping_demo_freertos_frdmk64f.elf'.
How can i solve this? if i compile in debug mode no problem is found, but in release mode this problem appears
thanks
2,465 次查看
Carlos_Musich
Hi Pablo,
Carlos
