What is the writing limit on a SD card 8G
ソリューションへジャンプ
1,442件の閲覧回数
neilporven
Senior Contributor I
Hi everyone,
I am using FatFs 0.9b and I would like to know what is its limit?  I have a 8G SD card.
Neil
1,242件の閲覧回数
isaacavila
Hello Neil,
Have you tried by using f_getfree API?
Here you can find more information: FatFs - f_getfree
And also, in host_msd_fatfs_bm_frdmk64f example (KSDK 1.3) this API is used to get the available space in the disk:
/* Get free clusters */
returnCode = f_getfree(_T("0:"), &fre_clust, &fs);
USB_PRINTF("%lu KB total disk space.\n\r%lu KB available.\n\r", (((fs->n_fatent - 2) * (fs->csize)) / 2), ((fre_clust * (fs->csize)) / 2));
I hope this can help!
Isaac
3 返答(返信)
1,242件の閲覧回数
neilporven
Quick Update,
I filled the 8G SD card to max cap.
The only thing that could signal that I reached the end is that in f_lseek or f_open .... etc..... the first parameter FIL internal variables
fptr = fsize.  Is it correct to assume once this condition is reached that the card is full?
Neil
1,243件の閲覧回数
isaacavila
Hello Neil,
Isaac
1,242件の閲覧回数
neilporven
Thanks Isaacavila,
The f_getfree is what I was looking for, it helped me.
Neil
