“Term”
已解决
“Term”
跳至解决方案
2,435 次查看
shauldorf
Contributor V
What is the reason that “Term” component isn’t supported in KSDK1.2 ?
Shaul
标签 (1)
1 解答
2,262 次查看
ZhangJennie
hi Shaul,
as I know, ksdk component doesn;t have exact Term feature.
I suggest you escalate it as a feature request to [email protected]
hope this helps!
Zhang Jun
在原帖中查看解决方案
3 回复数
2,262 次查看
shauldorf
Contributor V
Hello Jennie,
Thanks’
Using Term component there are methods to manipulate cursor and screen clear that are not used by printf operations.
How screen operation can be implemented using fsl_xxx components?
Shaul
2,263 次查看
ZhangJennie
hi Shaul,
hope this helps!
Zhang Jun
2,261 次查看
ZhangJennie
Term component is legacy component that generated code doesn't support KSDK low level driver.
Freescale creates a set of KSDK compatible component, start with fsl_xxx or Init_xxx
We can use KSDK with processor expert to print string to console. See this document:
https://community.freescale.com/docs/DOC-104349
can this help you?
Zhang Jun
