TCP Client using KDSK_1.3.0 for K64 MCU
3,037件の閲覧回数
punitkumar
I'm using lwIP tcpecho demo example given with KDSK1.3.0.
It successfully connected to TCP client as server, but my application needs TCP client on K64 MCU.
How can i make TCP client on K64 using KSDK.
Punit Kumar
6 返答(返信)
2,642件の閲覧回数
ivadorazinova
Hi Punit,
please can you try it according this example?
TCP Client Server Example
LWIP stack is CPU independent.
I hope this helps.
In case of any issue, please let me know.
Kind Regards,
Iva
2,642件の閲覧回数
punitkumar
Thanks ivadorazinova​
Will this example works for baremetal project?
Best Regards
Punit Kumar
2,642件の閲覧回数
ivadorazinova
Hi Punit.
Yes,also for baremetal project. independently on OS.
Iva
2,642件の閲覧回数
punitkumar
Hi ivadorazinova​
thanks for the response.
I've implimented TCP client using raw api of lwIP.
But i cannot detect a connection drop (removed cable) after once connected successfully.
can you help me over that?
thanks in advance
Punit Kumar
2,642件の閲覧回数
ivadorazinova
Hello Punit.
I very apologize for my late response.
Please, did you solve your issue or could I help you?
Thank you for your feedback!
Have a great day!
Iva
2,642件の閲覧回数
punitkumar
Thanks for your response,
I've made it worked, but now have another problem regarding the same.
you can find it with title "problem while TCP Transmission of continuous data"
Reply if you can help me over that.
I've used RAW APIs.
Thanks Again
Punit Kumar
