Secure Bootloader AES help
marcobologna
Hello!
I would like to use on kinetis KV11Z and MK22FX the bootloader with security aes.
When I try to compile, it asks me for the file aes_security.h and I can't find it.
Can anyone help me?
Is there a step by step tutorial that helps to implement security aes in bootloader 2.5?
Thanks in advance.
Marco
jingpan
MCUboot has been integrated into SDK. You can find this file in SDK_2.6.0_TWR-K22F120M\middleware\mcu-boot\tools\tools\elftosb\common
Jing
jingpan
Hi Macro,
aes_security.h and aes_security.c use MMCAU. This is a special hardware that KV11 and K22 haven't.You can only use software encryption and decryption. The code is in aes128_key_wrap_unwrap.c
Jing
marcobologna
Dear Jing
Thanks for your reply.
The aes128_key_wrap_unwrap.c is missing in the MCU-BOOT v 2.5  source code. How I can find it and how I can insert it? How use it?
Marco
jingpan
Jing
marcobologna
Hi Jing,
Thanks for your help. We solved the problem.
Marco
