LWIP_INIT
LWIP_INIT
pietrodicastri
Senior Contributor II
Good morning
I need to reinit the stack run time. I tried to use the lwip_init() but it craches.
Has someone a good suggestion on how to reinit the stack at a later time???
Thank You
Pietro
pietrodicastri
Hi Daniel
I did not process so quickly. Thank You for the suggestion. I will try to do in such way.
Pietro
danielchen
Hi Pietro:
This is not a normal use case for embedded system. lwip stack maybe not support it. I would suggest you post this question to the lwip official forum.
