Is there a way to erase flash through hardware?
duan050790
Is there a way to erase flash through hardware?My SWD can not recongnize the KEAZ128 controller.
duan050790
Thanks,I have solved this problem by pull low the reset pin while power on.
jingpan
I'm afraid that there is no other way to erase flash except SWD. KEAZ128 hasn't EZport. New KEAZ128 chip also hasn't bootloader. So you must have the SWD work.
Good luck!
Jing
