Is there a way to erase flash through hardware?
1,596件の閲覧回数
duan050790
Is there a way to erase flash through hardware?My SWD can not recongnize the KEAZ128 controller.
2 返答(返信)
1,496件の閲覧回数
duan050790
Thanks,I have solved this problem by pull low the reset pin while power on.
1,496件の閲覧回数
jingpan
I'm afraid that there is no other way to erase flash except SWD. KEAZ128 hasn't EZport. New KEAZ128 chip also hasn't bootloader. So you must have the SWD work.
Good luck!
Jing
