Implementing a watchdog with an example
1,441件の閲覧回数
Kewal
I am currently using K64 processor, so I am trying to find an example or a way to use fsl_wdog.
Is there any manual / documentation  available for the components found in the component library. I have also tried to figure out about configuring components the hardway.
1,168件の閲覧回数
ivadorazinova
Hi Kewal Deshpande ,
please refer to example for KSDK 2.0,
in case of FRDM-K64 is at <KSDK2.0_FRDMK64_installation_path>\boards\frdmk64f\driver_examples\wdog\
This driver is described in API Reference Manual located under <KSDK2.0_FRDMK64_installation_path>\SDK_2.0_TWR-K65F180M\docs
I hope this helps you !
Iva
