High speed USB 2 supported by SDK 1.3 and K66 ?
1,102 次查看
gpontis
Title says it all: does the SDK v1.3 with MQX support high speed USB on the K66 ( or K65 ) ?
1,011 次查看
ivadorazinova
Hi George.
Yes exactly. Both K65 and K66 have this capability USB High Speed.
But in KSDK 1.3 is supported only K65. Not K66.
If you go to the header file at C:\Freescale\KSDK_1.3.0\examples\twrk65f180m\demo_apps\usb\device\msd\usb_descriptor.h here you should enable the macro HIGH_SPEED     1
I hope this helps.
Iva
