FRDM-KL27 ADC DEMO
FRDM-KL27 ADC DEMO
1,892件の閲覧回数
profitt
I am using the frdm-kl27z with adc16 interrupt driver demo to test ADC.
In the debug serial output, when I hold any key, the sample value increased slowly and at last reached 4095.
I changed the sample channel to temp sensor got the same result.
What is the problem in my test. THANKS!
1,761件の閲覧回数
xiangjun_rong
Hi, Mel,
I suppose that you do not connect the ADC ananlog pin to a GND or VDD or a divider, you have the ADC analog pin float, which leads to the ADC sample indeterminate.
Pls connect the analog ADC pin to GND or VDD or to a divider, have a try.
If you still have issue, pls post your code so that we have a review.
Hope it can help you
Xiangjun Rong
