I have tried to install EmbSys Viewer on KDS 3.2 with Luna 4.4. I followed the methods described in this forum and on mcuoneclipse.com When I try to specify the device (K22F), NXP or Freescale is not listed in the vendor listing. Any suggestions?
Are the NXP/Freescale SVD files present in your data files/collection for EmbSysRegView?
Depending on your EmbSysRegView, this might be different, see Adding CMSIS-SVD Files to EmbSysRegView 0.2.6.r192 and Eclipse | MCU on Eclipse
I hope this helps,
Erich
I think you mean the 'SVD(CMSIS)' folder. Not sure why it does not list it for you. But in any case, you can pick and choose any folder name or move files into a folder of your choice inside the data.
Can you check the SVD folder in that zip file?
Working now.
Simply need to select SVD(CMSIS) under Architecture in the EmbSysReg
section and then select Freescale. A bit different approach from the
article since I didn't create a KDS directory and copy the files. This
is not easy if you don't have Winzip Pro. So I simply left it as is.
You don't need WinZip Pro. Any zip tool (as 7-Zip) can do this.
