HALLSENSOR _XOR OPERATION KV31
2,307件の閲覧回数
pandi
HI
@xiangjun_rong
@_Leo_
NXP Tech
In KV31  FTM1 and FTM2 channels  Input capture method configured. SIM->SIM_SOPT4  enabled . FTM  3 channels also interrupt enabled.FTM2 CH1 interrupt to checking hall signal based interrupt not working. configured this method if any thing missing  configuration let me know anyone and guide me.
Checking FTM2 interrupt and  FTM 2 channel pin to connected Hall sensor. This function any thing change  you have to guide me.
                                      Thank you
PANDI
2,287件の閲覧回数
_Leo_
Thank you so much for your interest in our products and for using our community.
In the KV3x page, there is the application note AN12374 PMSM Field-Oriented Control on FRDMKV31F with Hall and Encoder Sensors with its respective SW file. In the code you can check the initialization and operation of the FTM2, which performs hall sensors signal processing.
Hope it helps you.
Have a nice day!
2,273件の閲覧回数
pandi
@_Leo_
Thank you for your message.
PANDI
