Debug interface recommendations for Kinetis and LPC?
richard37
I do most of my development on the Kinetis series, and potentially some LPC parts in the near future. I've got a drawer full of debug interfaces from P&E Micro, including a Cyclone ACP that I use most.
I sometimes find myself switching from the $600 Cyclone to the $20 LPC-Link2 because the Cyclone has so many weird problems with MCUXpresso. Honestly the LPC-Link2 does most of what I need, it's just a bit slow.
Should I be looking at Segger interfaces? Can someone recommend a reliable, reasonably fast interface that's well-supported in MCUXpresso (and hopefully CodeWarrior 11 as well) that doesn't cause crashes all of the time, or fail to halt a running target? Trace support would be nice.
Thanks!
carlos_o
Hi @richard37
Thank you for your post!
You may want to consider a SEGGER J-Link. It supports both Kinetis and LPC devices when used with MCUXpresso, and it is also natively supported by CodeWarrior 11.
This makes it a good alternative if you need a debug probe that can be used across both development environments and device families.
%3CLINGO-SUB%20id%3D%22lingo-sub-2404221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDebug%20interface%20recommendations%20for%20Kinetis%20and%20LPC%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20do%20most%20of%20my%20development%20on%20the%20Kinetis%20series%2C%20and%20potentially%20some%20LPC%20parts%20in%20the%20near%20future.%20I've%20got%20a%20drawer%20full%20of%20debug%20interfaces%20from%20P%26amp%3BE%20Micro%2C%20including%20a%20Cyclone%20ACP%20that%20I%20use%20most.%3C%2FP%3E%3CP%3EI%20sometimes%20find%20myself%20switching%20from%20the%20%24600%20Cyclone%20to%20the%20%2420%20LPC-Link2%20because%20the%20Cyclone%20has%20so%20many%20weird%20problems%20with%20MCUXpresso.%20Honestly%20the%20LPC-Link2%20does%20most%20of%20what%20I%20need%2C%20it's%20just%20a%20bit%20slow.%3C%2FP%3E%3CP%3EShould%20I%20be%20looking%20at%20Segger%20interfaces%3F%20Can%20someone%20recommend%20a%20reliable%2C%20reasonably%20fast%20interface%20that's%20well-supported%20in%20MCUXpresso%20(and%20hopefully%20CodeWarrior%2011%20as%20well)%20that%20doesn't%20cause%20crashes%20all%20of%20the%20time%2C%20or%20fail%20to%20halt%20a%20running%20target%3F%20Trace%20support%20would%20be%20nice.%3C%2FP%3E%3CP%3EThanks!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404315%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Debug%20interface%20recommendations%20for%20Kinetis%20and%20LPC%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404315%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F265538%22%20target%3D%22_blank%22%3E%40richard37%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20your%20post!%3C%2FP%3E%0A%3CP%3EYou%20may%20want%20to%20consider%20a%20SEGGER%20J-Link.%20It%20supports%20both%20Kinetis%20and%20LPC%20devices%20when%20used%20with%20MCUXpresso%2C%20and%20it%20is%20also%20natively%20supported%20by%20CodeWarrior%2011.%3C%2FP%3E%0A%3CP%3EThis%20makes%20it%20a%20good%20alternative%20if%20you%20need%20a%20debug%20probe%20that%20can%20be%20used%20across%20both%20development%20environments%20and%20device%20families.%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
