Custom Hardware UART modification.pdf
Comments
I just tried this again with MCUXpresso release 10.2 Build 759 and ran into a pin naming convention change.
The pins that used to be named with GPIO_PIN in the define name [for example BOARD_LED1_GPIO_PIN] have changed and now remove the GPIO_ from the name string [for example BOARD_LED1_PIN].
This change resulted in a number of compile errors.
With a simple change of the define name references all of the compile errors were eliminated.
Philip Drake
%3CLINGO-SUB%20id%3D%22lingo-sub-1127798%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECustom%20Hardware%20UART%20modification.pdf%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127798%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1127798%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1127798%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EArchive%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127799%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Custom%20Hardware%20UART%20modification.pdf%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127799%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20just%20tried%20this%20again%20with%20MCUXpresso%20release%2010.2%20Build%20759%20and%20ran%20into%20a%20pin%20naming%20convention%20change.%26nbsp%3B%20%3C%2FP%3E%3CP%3EThe%20pins%20that%20used%20to%20be%20named%20with%20GPIO_PIN%20in%20the%20define%20name%20%5Bfor%20example%20BOARD_LED1_GPIO_PIN%5D%20have%20changed%20and%20now%20remove%20the%20GPIO_%20from%20the%20name%20string%20%5Bfor%20example%26nbsp%3BBOARD_LED1_PIN%5D.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThis%20change%20resulted%20in%20a%20number%20of%20compile%20errors.%26nbsp%3B%3C%2FP%3E%3CP%3EWith%20a%20simple%20change%20of%20the%20define%20name%20references%20all%20of%20the%20compile%20errors%20were%20eliminated.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3EPhilip%20Drake%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎03-05-2018 01:58 PM
Updated by:
