Commanding a Motor Speed Toque or Position in a KMS reference project
Introduction:
KMS has a built in Motion Sequence Builder tool that gives you a very quick way of commanding various motor control scenarios.  If your motor control device requires external control of the speed, position or torque you will need to adapt the provided KMS reference design to your needs.
I recommend you start by using the Motion Sequence Builder to create a plan and variables that resemble your application. Examples provided include a blender, a ceiling fan and a washing machine for speed control and a security camera panning example for position control.
After completing the KMS GUI motor commissioning and experimenting with your motion plan, you will want to drive your motor within your application without the GUI and outside the bounds of the motion plan.  Now to create your own control system, to commanded speed, torque or position driven from another source.
This document covers the basics of performing those commands. In these example you will be interacting with the User block.  The User block aggregates the main motor operating states capable of being called by the user. This is intended to provide an easy, consistent code interface for the user to be able to command a specific operating state and perform certain common configurations of the desired state.
Knowing the State of the Motor:
Before you tell the motor to go-to-speed, or go-to-position, or command a torque, you need to know that the motor is ready to accept your command.  I strongly suggest you read Chapter 2 of the KMS API reference manual.  Some of the text below is copied from there.
States that can be accessed via the User block include:
  • Idle
  • Fault
  • Self-commissioning (SCM)
  • Inertia Estimation (Inertia)
  • PWM Duty Control
  • Voltage Control
  • Current Control (Current)
  • Speed Control (Speed)
  • Position Control (Position) [Sensored Position]
  • Motion Sequence (Plan)
  • Braking (Brake)
  • Encoder Alignment (Align) [Sensored Velocity or Sensored Position]
Once in a state you can update the speed or position or torque directly.  Prior to entering the user state that commands speed, position or torque you need to take the input and covert it to the proper units.
Where to put your Control Code:
In the main loop, the code snippet below checks the state of the DC bus and the Fault indicator.
/* DC BUS Charging Indicator */
  if(DRV_getDcbBusVoltage()<DRV_getDcbBusUnderVoltageThreshold()||DRV_getIsFaultActive())
            BUS_VOLTAGE_LEDOFF;
        else
            BUS_VOLTAGE_LEDON;
        /* FAULT Indicator */
        if (DRV_getIsFaultActive()) // Pulled Up Switch is Active Low
            FAULT_LEDON;
        else
            FAULT_LEDOFF;
You can put your control code in this loop or better yet you can put your control code in the interrupt service routine that executes at the slow tick rate.
 * @fn      SWI_IRQHandler(void)
 * @brief   Run slow isr task
 * @return  None
 * @ingroup SLOW_ISR
void SWI_IRQHandler(void)
    static timestamp_t SlowIsrStartLast = 0;
    /*!< Previous Start of ISR timestamp for measuring period  */
    timestamp_t startCycleCount = GetProfilerCycles();
    CpuUtilization.SlowIsrPeriod = startCycleCount -SlowIsrStartLast;
    SlowIsrStartLast = startCycleCount;
    /* Clear source of ISR */
    NVIC_ClearPendingIRQ(SWI_IRQn);
    /* Update drive module */
    DRV_updateSlowTick();
    /* Diagnostic counter */
    slowTicks++;;‍‍‍‍‍‍
    /* insert control code here  for example test for state*/
    /*LED1 to indicate motor in Plan mode */
    if(user.state == USER_RUN_PLAN)
        LED4_ON;
    else
        LED4_OFF;
Conversion:
The conveyor example below has two inputs derived from the ADC result register. In the next code listing, the inputs values are scaled and converted to LQ format. These controls are demonstrated in the conveyor belt demonstration shown in the video Kinetis Motor Control Made Easy. The two potentiometers shown in the picture are fed into an ADC channel.
   /*poll external outputs*/
    /*GPIO have HW enabled anti-glitch and Pullup*/
    /*1 = on 0 = off */
    userPlanVariables.On_Off=!((bool)GPIO_DRV_ReadPinInput(kGpioOnOff));
    /*high = 1, low = 0 */
    userPlanVariables.Low_High=(bool)GPIO_DRV_ReadPinInput(kGpioHighLow);
    /*in High speed operation need slightly higher bandwidth */
    if(userPlanVariables.Low_High == 0)
        userPlanVariables.Bandwidth_High = _LQ20(70.0);
        userPlanVariables.Bandwidth_Low = _LQ20(10.0);
    else
        userPlanVariables.Bandwidth_High = _LQ20(100.0);
        userPlanVariables.Bandwidth_Low = _LQ20(15.0);
    /*Value Scaled to 0-1 in LQ Format Q12->GlobalLQ*/
 userPlanVariables.Bandwidth_Scale=_LQXtoLQY(adc0Results[0],12,GLOBAL_LQ);
 position
.config.lq20Bw_radps = _LQ20mpyLQX( userPlanVariables.Bandwidth_High - userPlanVariables.Bandwidth_Low , 20U, userPlanVariables.Bandwidth_Scale ,GLOBAL_LQ) \
+ userPlanVariables.Bandwidth_Low;
/*Value Scaled to 0-1 in LQ Format with light exponential weighting .5821*(e^x-1)*/
 userPlanVariables
.Jerk_Scale=_LQmpy(_LQXtoLQY(_LQ20exp(_LQXtoLQY(adc1Results[0],12,20U)),20,GLOBAL_LQ)-_LQ(1.0),\
_LQ(0.581992));‍‍‍‍‍‍‍
You cannot just set the target speed like this using and integer value for RPM.
user.command.targetSpeed = 100;
The KMS code uses QMath in the calculations. Conversion of a float or integer to a LQ type is easy to do using the API calls. Check out Chapter 24 Math for the details on the QMath library.
In KMS all values are normalized fixed-point.  So setting user.command.targetSpeed to 100 sets the target speed to a very small value (<< 1RPM).
You need to convert from RPM into the normalized fixed point used by KMS.
user.command.targetSpeed = _LQ(100.0 / FULL_SCALE_SPEED_RPM);
In the above line, FULL_SCALE_SPEED_RPM represents the maximum possible speed in the system.  Dividing the input speed of 100.0 by this value will convert your input into a normalized value.  Since KMS is also fixed point, we need to convert this normalized floating-point number to fixed point.  The macro _LQ will convert from floating point into fixed point at the default Qness.  The variable user.command.targetSpeed is defined as an _lq variable.  This means it is a 32-bit container with a Qness of 24 (24 bits after the decimal point).  By default all _lq variables default to Q24 unless otherwise noted in the variable name.
Commanding Speed:
In the KMS_API RM, the user block is defined. The user.state definitions are in the user.h file.
If you want to idle the motor you would write:
user.stateUSER_IDLE;
To set the user state to run speed you would write:
user.stateUSER_RUN_SPEED;
Here is a list of all the USER_States for speed control.
 * @enum USER_state_e
 * @brief USER state-machine states
typedef enum
 USER_IDLE
= 0, /**< 0: USER IDLE state */
 USER_FAULT
= 1, /**< 1: USER FAULT state */
 USER_SCM
= 2, /**< 2: USER self-commissioning state */
 USER_INERTIA
= 3, /**< 3: USER inertia estimation state */
 USER_RUN_DUTY
= 4, /**< 4: DSM run PWM duty control state */
 USER_RUN_VOLTAGE
= 5, /**< 5: DSM run voltage control state */
 USER_RUN_CURRENT
= 6, /**< 6: USER run current control state */
 USER_RUN_SPEED
= 7, /**< 7: USER run speed control state */
 USER_RUN_PLAN
= 8, /**< 8: USER run a motion plan state */
 USER_BRAKE
= 9, /**< 9: USER braking state */
} USER_state_e;‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
If you use the feedback_3ph.c as an example piece of code, the raw ADC reading is converted to a _sq with the use of the function (_sq): tempSQ = (_sq)(adcResults->phaseBCurrent - v->calib.offsetIb);
Likewise, the conversion of the RAW ADC result to LQ is accomplished using the (_lq) function.
In the following code example an ADC input is used to control the speed. The code below, takes the ADC results and converts it to an _lq type by means of the following statement:
adc0Results[0] = (_lq) adc0RawResults[0];
/* code start */
// declare these as global variables in main.c
_lq adcSpeed
= 0;
_lq adcSpeedAccum
= 0;
_lq adcSpeedAvg
= 0;
uint16_t speedUpdateCounter
= 0;
// this code takes the ADC reading, downshifts it by 4 to remove noise and uses that as a percentage of the maximum applicaton speed (in this case 20krpm)
adcSpeed
= _LQmpyLQX((adc0Results[0] >> 4), 8, _LQ(20000.0/FULL_SCALE_SPEED_RPM), 24);
adcSpeed
= _LQsat(adcSpeed, _LQ(1.0), _LQ(0.0));
// this code averages the adc reading over 125 samples before setting it to user.command.targetSpeed
// it will also handle setting the control mode if the commanded speed is larger than 0
if(adcSpeed > _LQ(0.0))
                user
.state= USER_RUN_SPEED;
if(speedUpdateCounter >= 125)
                     speedUpdateCounter
= 0;
                     adcSpeedAvg
=(adcSpeedAccum/125)&0x00FF0000;
                     user
.command.targetSpeed = adcSpeedAvg;
                     adcSpeedAccum
= 0;
else
                     adcSpeedAccum
= adcSpeed + adcSpeedAccum;
                     speedUpdateCounter
else
        user
.state= USER_IDLE;
        adcSpeedAccum
= 0;
        adcSpeedAvg = 0;
        speedUpdateCounter
= 0;
Setting command Values:
Before you change a user.state there are parameters like acceleration and jerk you can modify. Prior to change the state you can update any number of other command values list in the function below. The list gives a quick look at the parameters you can update prior to changing the motor state. Each of the command values listed can be updated prior to this call. As you can see, setting the speed value in the line containing command.targetSpeed is just one of five values sent to the drive command.
After setting these parameters, you command a state change to USER_RUN_SPEED
The user state “USER_RUN_SPEED” executes this function which start the motor on the new trajectory.
 * @fn USER_runSpeedState(USER_t *pUSER, SPEED_t *speed, DRV_control_e controlType, \
 * TRF_rVector16_t startupStatorRefCurrent, _sq fwIdRef)
 * @brief Runs the Speed Control USER state
 * @param pUSER - pointer to the USER block
 * @return none
static void USER_runSpeedState(USER_t *pUSER)
/* For trajectory, just send command values to DRV*/
 pUSER
->output.drvCommand.targetSpeed = pUSER->command.targetSpeed;
 pUSER
->output.drvCommand.limitAcc = pUSER->command.limitAcc;
 pUSER
->output.drvCommand.lq20LimitJerk = pUSER->command.lq20LimitJerk;
 pUSER
->output.drvCommand.IqRefMax = pUSER->command.IqRefMax;
 pUSER
->output.drvCommand.IqRefMin = pUSER->command.IqRefMin;
/* Run trajectory generator in this state */
 pUSER
->output.drvCommand.runTrajectory = true;
return;
} /* end of USER_runSpeedState() */‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Commanding Torque:
If you wanted to command torque (current), then you would initialize the command values identified in the code below. In addition to command .statorRefCurrent, you can specify a command.targetSpeed.
 * @fn USER_runCurrentState(USER_t *pUSER)
 * @brief Runs the Current control USER state
 * @return none
static void USER_runCurrentState(USER_t *pUSER)
 pUSER
 pUSER
 pUSER
 pUSER
->output.drvCommand.statorRefCurrent = pUSER->command.statorRefCurrent;
 pUSER
->output.drvCommand.enableDCInjection = pUSER->command.enableDCInjection;
return;
} /* end of USER_runCurrentState() */‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Commanding Position:
When using KMS to control a position, the call to the following function is made.  The motor position control follows a trajectory that you choose prior to the call by setting the command values to the motor drive state machine. In the position control reference project include file "user.h" there are two more USER state-machine states added to the list of USER_STATES -> USER_RUN_POSITION and USER_ALIGN.
typedef enum
    USER_IDLE
    USER_FAULT
    USER_SCM
    USER_INERTIA
    USER_RUN_DUTY
    USER_RUN_VOLTAGE
    USER_RUN_CURRENT
    USER_RUN_SPEED
= 7, /**< 7: USER run position-controlled speed state */
    USER_RUN_PLAN
    USER_BRAKE
    USER_RUN_POSITION
= 10, /**< 10: USER run position control state */
    USER_ALIGN
= 11  /**< 11: USER force motor into alignment */
} USER_state_e;
To command a position, set the command values and then set the state to USER_RUN_POSITION
user.stateUSER_RUN_POSITION;
This will result in a trajectory to be executed.
 * @fn USER runSpeedState(USER_t *pUSER,SPEED_t *speed,DRV_control_e controlType,
 * @return none
static void USER_runPositionState(USER_t *pUSER)
 pUSER
->output.drvCommand.runTrajectory = pUSER->command.runTrajectory;
 pUSER
->output.drvCommand.posStepInt_mrev = pUSER->command.posStepInt_mrev;
 pUSER
->output.drvCommand.posStepFrac_mrev = pUSER->command.posStepFrac_mrev;
 pUSER
->output.drvCommand.limitVel = pUSER->command.limitVel;
 pUSER
 pUSER
->output.drvCommand.limitDec = pUSER->command.limitDec;
 pUSER
 pUSER
 pUSER
/* Run trajectory generator in position mode */
 pUSER
->output.drvCommand.velocityMode = false;
return;
} /* end of USER_runSpeedState() */‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Below is a bare metal code example used to drive the X or Y axis of a position controller.  The UART receives the command and a sync pulse on a GPIO starts the trajectory profile. This is not very robust code with very little command format checking.  I encourage you to consider the limit conditions and correctness of the input command values before using them to command the motor position.  This code tends to occasionally miss-fire and send the 3D printer base flying to the end stop.
user.state = USER_RUN_POSITION;
while (true)
// LED2 GREEN is DC BUS Charging Indicator, disable if fault
if (DRV_getDcbBusVoltage() < DRV_getDcbBusUnderVoltageThreshold() || DRV_getIsFaultActive()) LED2_OFF; else LED2_ON;
// Expected format: xAAAAAAAABBBBBBBBX
// Wait for initial 'x' or 'y', remember to set this in axis variable
GPIOC_PSOR
=(1<<3); //set buffer ready
do {cin=UART1_CharIn();} while (cin!=axis);
// Read AAAAAAAA (dx as a float)
mem
=(byte *)&f1; for (i=0;i<4;i++) {*mem=UART1_ByteIn(); mem++;}
// Read BBBBBBBB (dy as a float)
mem
=(byte *)&f2; for (i=0;i<4;i++) {*mem=UART1_ByteIn(); mem++;}
// Wait for final 'X' or 'Y': if not an 'X' or 'Y', ignore message
cin
=UART1_CharIn();
if (cin==axis-32)
 GPIOC_PCOR
=(1<<3);
UART_CharOut(axis);
// Valid Message, go ahead and execute
// ROTATION: extract integer part of rotation
 value
=(int)f1;
 user
.command.posStepInt_mrev=value;
//UART_TextOut("IntRotation=");
UART_DbleOut(value,4,1);
// ROTATION: extract fractional part of rotation
 user
.command.posStepFrac_mrev=_LQ(f1-value);
//UART_TextOut("FracRotation=");
UART_DbleOut(f1-value,4,4);
// SPEED: extract integer part of rotation
 f2
=f2/4000.0;
 user
.command.limitVel=_LQ(f2);
//UART_TextOut("SpeedRPM=");
UART_DbleOut(f2,4,4);
 GPIOC_PSOR
=(1<<6);
// Wait for Sync
while (((GPIOE_PDIR&(1<<6))==0));
 GPIOC_PCOR
=(1<<6);
 flag
=0; done=1; user.command.runTrajectory=1;
while (done==1) {UART_CharOut('1');}
 GPIOC_PSOR
=(1<<6);
}//while (true)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Conclusion:
Four steps are needed:
  1. Check the existing state of the motor, managing faults and trajectories.
  2. Convert the commanded inputs to the fixed-point values needed by KMS.
  3. Set the configuration parameters, like acceleration, jerk and speed.
  4. Change the user state to the desired state, Speed, Torque, Position.
Philip Drake
Systems Applications Engineer
标签 (1)
%3CLINGO-SUB%20id%3D%22lingo-sub-1108011%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%20KMS%20%E5%8F%82%E8%80%83%E9%A1%B9%E7%9B%AE%E4%B8%AD%E6%8E%A7%E5%88%B6%E7%94%B5%E6%9C%BA%E9%80%9F%E5%BA%A6%E3%80%81%E6%89%AD%E7%9F%A9%E6%88%96%E4%BD%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108011%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20green%3B%20font-size%3A%2018.0pt%3B%22%3E%3CSTRONG%3E%E4%BB%8B%E7%BB%8D%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSTRONG%3EKMS%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%86%85%E7%BD%AE%E8%BF%90%E5%8A%A8%E5%BA%8F%E5%88%97%E7%94%9F%E6%88%90%E5%99%A8%E5%B7%A5%E5%85%B7%EF%BC%8C%E5%8F%AF%E8%AE%A9%E6%82%A8%E5%BF%AB%E9%80%9F%E6%8E%A7%E5%88%B6%E5%90%84%E7%A7%8D%E7%94%B5%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%9C%BA%E6%99%AF%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E7%9A%84%E7%94%B5%E6%9C%BA%E6%8E%A7%E5%88%B6%E8%AE%BE%E5%A4%87%E9%9C%80%E8%A6%81%E5%A4%96%E9%83%A8%E6%8E%A7%E5%88%B6%E9%80%9F%E5%BA%A6%E3%80%81%E4%BD%8D%E7%BD%AE%E6%88%96%E6%89%AD%E7%9F%A9%EF%BC%8C%E5%88%99%E9%9C%80%E8%A6%81%E6%A0%B9%E6%8D%AE%E9%9C%80%E6%B1%82%E8%B0%83%E6%95%B4%E6%8F%90%E4%BE%9B%E7%9A%84%20KMS%20%E5%8F%82%E8%80%83%E8%AE%BE%E8%AE%A1%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E9%A6%96%E5%85%88%E4%BD%BF%E7%94%A8%E8%BF%90%E5%8A%A8%E5%BA%8F%E5%88%97%E7%94%9F%E6%88%90%E5%99%A8%E6%9D%A5%E5%88%9B%E5%BB%BA%E7%B1%BB%E4%BC%BC%E4%BA%8E%E6%82%A8%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E8%AE%A1%E5%88%92%E5%92%8C%E5%8F%98%E9%87%8F%E3%80%82%E6%8F%90%E4%BE%9B%E7%9A%84%E7%A4%BA%E4%BE%8B%E5%8C%85%E6%8B%AC%E7%94%A8%E4%BA%8E%E9%80%9F%E5%BA%A6%E6%8E%A7%E5%88%B6%E7%9A%84%E6%90%85%E6%8B%8C%E6%9C%BA%E3%80%81%E5%90%8A%E6%89%87%E5%92%8C%E6%B4%97%E8%A1%A3%E6%9C%BA%E4%BB%A5%E5%8F%8A%E7%94%A8%E4%BA%8E%E4%BD%8D%E7%BD%AE%E6%8E%A7%E5%88%B6%E7%9A%84%E5%AE%89%E5%85%A8%E6%91%84%E5%83%8F%E6%9C%BA%E6%91%87%E6%91%84%E7%A4%BA%E4%BE%8B%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%AE%8C%E6%88%90%20KMS%20GUI%20%E7%94%B5%E6%9C%BA%E8%B0%83%E8%AF%95%E5%B9%B6%E8%AF%95%E9%AA%8C%E6%82%A8%E7%9A%84%E8%BF%90%E5%8A%A8%E8%AE%A1%E5%88%92%E5%90%8E%EF%BC%8C%E6%82%A8%E5%B0%86%E5%B8%8C%E6%9C%9B%E5%9C%A8%E6%B2%A1%E6%9C%89%20GUI%20%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%9C%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%86%85%E9%A9%B1%E5%8A%A8%E7%94%B5%E6%9C%BA%EF%BC%8C%E5%B9%B6%E4%B8%94%E8%B6%85%E5%87%BA%E8%BF%90%E5%8A%A8%E8%AE%A1%E5%88%92%E7%9A%84%E8%8C%83%E5%9B%B4%E3%80%82%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%E7%8E%B0%E5%9C%A8%E5%88%9B%E5%BB%BA%E6%82%A8%E8%87%AA%E5%B7%B1%E7%9A%84%E6%8E%A7%E5%88%B6%E7%B3%BB%E7%BB%9F%EF%BC%8C%E4%BB%A5%E4%BB%8E%E5%8F%A6%E4%B8%80%E4%B8%AA%E6%BA%90%E6%8E%A7%E5%88%B6%E9%80%9F%E5%BA%A6%E3%80%81%E6%89%AD%E7%9F%A9%E6%88%96%E4%BD%8D%E7%BD%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E6%9C%AC%E6%96%87%E6%A1%A3%E6%B6%B5%E7%9B%96%E6%89%A7%E8%A1%8C%E8%BF%99%E4%BA%9B%E5%91%BD%E4%BB%A4%E7%9A%84%E5%9F%BA%E7%A1%80%E7%9F%A5%E8%AF%86%E3%80%82%E5%9C%A8%E8%BF%99%E4%BA%9B%E7%A4%BA%E4%BE%8B%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%B0%86%E4%B8%8E%E7%94%A8%E6%88%B7%E5%9D%97%E8%BF%9B%E8%A1%8C%E4%BA%A4%E4%BA%92%E3%80%82%E7%94%A8%E6%88%B7%E5%9D%97%E8%81%9A%E5%90%88%E4%BA%86%E5%8F%AF%E4%BE%9B%E7%94%A8%E6%88%B7%E8%B0%83%E7%94%A8%E7%9A%84%E4%B8%BB%E8%A6%81%E7%94%B5%E6%9C%BA%E8%BF%90%E8%A1%8C%E7%8A%B6%E6%80%81%E3%80%82%E8%BF%99%E6%98%AF%E4%B8%BA%E4%BA%86%E7%BB%99%E7%94%A8%E6%88%B7%E6%8F%90%E4%BE%9B%E4%B8%80%E4%B8%AA%E7%AE%80%E5%8D%95%E3%80%81%E4%B8%80%E8%87%B4%E7%9A%84%E4%BB%A3%E7%A0%81%E7%95%8C%E9%9D%A2%EF%BC%8C%E4%BD%BF%E5%85%B6%E8%83%BD%E5%A4%9F%E5%91%BD%E4%BB%A4%E7%89%B9%E5%AE%9A%E7%9A%84%E6%93%8D%E4%BD%9C%E7%8A%B6%E6%80%81%E5%B9%B6%E6%89%A7%E8%A1%8C%E6%89%80%E9%9C%80%E7%8A%B6%E6%80%81%E7%9A%84%E6%9F%90%E4%BA%9B%E5%B8%B8%E8%A7%81%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2300b050%3B%20font-size%3A%2016.0pt%3B%22%3E%3CSTRONG%3E%E4%BA%86%E8%A7%A3%E7%94%B5%E6%9C%BA%E7%9A%84%E7%8A%B6%E6%80%81%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%9C%A8%E5%91%8A%E8%AF%89%E7%94%B5%E6%9C%BA%E5%8A%A0%E9%80%9F%E3%80%81%E5%AE%9A%E4%BD%8D%E6%88%96%E6%8C%87%E4%BB%A4%E6%89%AD%E7%9F%A9%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E7%9F%A5%E9%81%93%E7%94%B5%E6%9C%BA%E5%B7%B2%E5%87%86%E5%A4%87%E5%A5%BD%E6%8E%A5%E5%8F%97%E6%82%A8%E7%9A%84%E5%91%BD%E4%BB%A4%E3%80%82%3C%2FSPAN%3E%E6%88%91%E5%BC%BA%E7%83%88%E5%BB%BA%E8%AE%AE%E6%82%A8%E9%98%85%E8%AF%BB%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Freference-manual%2FKMSRM.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EKMS%20API%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%3C%2FA%3E%E7%9A%84%E7%AC%AC%202%20%E7%AB%A0%E3%80%82%E4%B8%8B%E9%9D%A2%E7%9A%84%E9%83%A8%E5%88%86%E6%96%87%E5%AD%97%E6%98%AF%E4%BB%8E%E9%82%A3%E9%87%8C%E5%A4%8D%E5%88%B6%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E7%94%A8%E6%88%B7%E5%9D%97%E8%AE%BF%E9%97%AE%E7%9A%84%E7%8A%B6%E6%80%81%E5%8C%85%E6%8B%AC%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%20%E7%A9%BA%E9%97%B2%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%20%E6%95%85%E9%9A%9C%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%20%E8%87%AA%E6%88%91%E8%B0%83%E8%AF%95%EF%BC%88SCM%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%20Inertia%20Estimation%20(Inertia)%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%20PWM%E5%8D%A0%E7%A9%BA%E6%AF%94%E6%8E%A7%E5%88%B6%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%20%E7%94%B5%E5%8E%8B%E6%8E%A7%E5%88%B6%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%20%E7%94%B5%E6%B5%81%E6%8E%A7%E5%88%B6%EF%BC%88%E7%94%B5%E6%B5%81%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%20%E9%80%9F%E5%BA%A6%E6%8E%A7%E5%88%B6%EF%BC%88%E9%80%9F%E5%BA%A6%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%20%E4%BD%8D%E7%BD%AE%E6%8E%A7%E5%88%B6%EF%BC%88%E4%BD%8D%E7%BD%AE%EF%BC%89%5B%E4%BC%A0%E6%84%9F%E4%BD%8D%E7%BD%AE%5D%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%20%E8%BF%90%E5%8A%A8%E5%BA%8F%E5%88%97%EF%BC%88%E8%AE%A1%E5%88%92%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%20%E5%88%B6%E5%8A%A8%EF%BC%88%E5%88%B9%E8%BD%A6%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%20%E7%BC%96%E7%A0%81%E5%99%A8%E5%AF%B9%E5%87%86%EF%BC%88%E5%AF%B9%E5%87%86%EF%BC%89%5B%E4%BC%A0%E6%84%9F%E9%80%9F%E5%BA%A6%E6%88%96%E4%BC%A0%E6%84%9F%E4%BD%8D%E7%BD%AE%5D%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E4%B8%80%E6%97%A6%E5%A4%84%E4%BA%8E%E6%9F%90%E7%A7%8D%E7%8A%B6%E6%80%81%EF%BC%8C%E6%82%A8%E5%B0%B1%E5%8F%AF%E4%BB%A5%E7%9B%B4%E6%8E%A5%E6%9B%B4%E6%96%B0%E9%80%9F%E5%BA%A6%E3%80%81%E4%BD%8D%E7%BD%AE%E6%88%96%E6%89%AD%E7%9F%A9%E3%80%82%E5%9C%A8%E8%BF%9B%E5%85%A5%E5%91%BD%E4%BB%A4%E9%80%9F%E5%BA%A6%E3%80%81%E4%BD%8D%E7%BD%AE%E6%88%96%E6%89%AD%E7%9F%A9%E7%9A%84%E7%94%A8%E6%88%B7%E7%8A%B6%E6%80%81%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E8%8E%B7%E5%8F%96%E8%BE%93%E5%85%A5%E5%B9%B6%E5%B0%86%E5%85%B6%E8%BD%AC%E6%8D%A2%E4%B8%BA%E9%80%82%E5%BD%93%E7%9A%84%E5%8D%95%E4%BD%8D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2300b050%3B%20font-size%3A%2016.0pt%3B%22%3E%3CSTRONG%3E%E6%8E%A7%E5%88%B6%E4%BB%A3%E7%A0%81%E6%94%BE%E5%9C%A8%E5%93%AA%E9%87%8C%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%9C%A8%E4%B8%BB%E5%BE%AA%E7%8E%AF%E4%B8%AD%EF%BC%8C%E4%B8%8B%E9%9D%A2%E7%9A%84%E4%BB%A3%E7%A0%81%E7%89%87%E6%AE%B5%E6%A3%80%E6%9F%A5%E7%9B%B4%E6%B5%81%E6%80%BB%E7%BA%BF%E5%92%8C%E6%95%85%E9%9A%9C%E6%8C%87%E7%A4%BA%E5%99%A8%E7%9A%84%E7%8A%B6%E6%80%81%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%2F*%20DC%20BUS%20%E5%85%85%E7%94%B5%E6%8C%87%E7%A4%BA%E7%81%AF%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E5%A6%82%E6%9E%9C%EF%BC%88DRV_getDcbBusVoltage%EF%BC%88%EF%BC%89%3CDRV_GETDCBBUSUNDERVOLTAGETHRESHOLD%3E%3C%2FDRV_GETDCBBUSUNDERVOLTAGETHRESHOLD%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E6%80%BB%E7%BA%BF%E7%94%B5%E5%8E%8BLED%E5%85%B3%E9%97%AD%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20else%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E6%80%BB%E7%BA%BF%E7%94%B5%E5%8E%8B_LED%20%E4%BA%AE%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%2F*%20%E6%95%85%E9%9A%9C%E6%8C%87%E7%A4%BA%E5%99%A8%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3Eif%20(DRV_getIsFaultActive())%20%2F%2F%20%E4%B8%8A%E6%8B%89%E5%BC%80%E5%85%B3%E5%A4%84%E4%BA%8E%E4%BD%8E%E7%94%B5%E5%B9%B3%E6%9C%89%E6%95%88%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20FAULT_LEDON%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20else%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E6%95%85%E9%9A%9C%E7%81%AF%E5%85%B3%E9%97%AD%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%7D%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%86%E6%8E%A7%E5%88%B6%E4%BB%A3%E7%A0%81%E6%94%BE%E5%85%A5%E6%AD%A4%E5%BE%AA%E7%8E%AF%E4%B8%AD%EF%BC%8C%E6%88%96%E8%80%85%E6%9B%B4%E5%A5%BD%E7%9A%84%E6%98%AF%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%86%E6%8E%A7%E5%88%B6%E4%BB%A3%E7%A0%81%E6%94%BE%E5%85%A5%E4%BB%A5%E6%85%A2%E9%80%9F%E6%BB%B4%E7%AD%94%E7%8E%87%E6%89%A7%E8%A1%8C%E7%9A%84%E4%B8%AD%E6%96%AD%E6%9C%8D%E5%8A%A1%E4%BE%8B%E7%A8%8B%E4%B8%AD%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233f7f5f%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%26nbsp%3B*%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F233122%22%3E%40FN%3C%2Fa%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20SWI_IRQHandler(void)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E*%20%40brief%20%E8%BF%90%E8%A1%8C%E6%85%A2%E9%80%9F%20isr%20%E4%BB%BB%E5%8A%A1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%26nbsp%3B*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E*%20%40return%20None%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E*%20%40ingroup%20SLOW_ISR%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%26nbsp%3B*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3Evoid%20SWI_IRQHandler(void)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%E9%9D%99%E6%80%81%E6%97%B6%E9%97%B4%E6%88%B3_t%20SlowIsrStartLast%20%3D%200%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F*!%26lt%3B%20%E4%B8%8A%E4%B8%80%E4%B8%AA%E6%B5%8B%E9%87%8F%E5%91%A8%E6%9C%9F%E7%9A%84%20ISR%20%E6%97%B6%E9%97%B4%E6%88%B3%E5%BC%80%E5%A7%8B%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3Etimestamp_t%20startCycleCount%20%3D%20GetProfilerCycles()%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3ECpuUtilization.SlowIsrPeriod%20%3D%20startCycleCount%20-SlowIsrStartLast%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3ESlowIsrStartLast%20%3D%20startCycleCount%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F*%20%E6%B8%85%E9%99%A4%20ISR%20%E6%BA%90%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3ENVIC_%E6%B8%85%E9%99%A4%E6%8C%82%E8%B5%B7IRQ%EF%BC%88SWI_IRQn%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20Update%20drive%20module%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20DRV_updateSlowTick()%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F*%20%E8%AF%8A%E6%96%AD%E8%AE%A1%E6%95%B0%E5%99%A8%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20slowTicks%2B%2B%3B%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2300b050%3B%20font-size%3A%2014.0pt%3B%20%22%3E%3CSTRONG%3E%3CEM%3E%2F*%20%E5%9C%A8%E6%AD%A4%E5%A4%84%E6%8F%92%E5%85%A5%E6%8E%A7%E5%88%B6%E4%BB%A3%E7%A0%81%E4%BE%8B%E5%A6%82%E6%B5%8B%E8%AF%95%E7%8A%B6%E6%80%81%20*%2F%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2011.5pt%3B%20%22%3E%3CSTRONG%3E%3CEM%3E%2F*LED1%20%E6%8C%87%E7%A4%BA%E7%94%B5%E6%9C%BA%E5%A4%84%E4%BA%8E%E8%AE%A1%E5%88%92%E6%A8%A1%E5%BC%8F%20*%2F%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2011.5pt%3B%20%22%3E%3CSTRONG%3E%3CEM%3E%E5%A6%82%E6%9E%9C%EF%BC%88%E7%94%A8%E6%88%B7.state%20%3D%3D%20USER_RUN_PLAN%EF%BC%89%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2011.5pt%3B%20%22%3E%3CSTRONG%3E%3CEM%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2011.5pt%3B%20%22%3E%3CSTRONG%3E%3CEM%3ELED4%E4%BA%AE%EF%BC%9B%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2011.5pt%3B%20%22%3E%3CSTRONG%3E%3CEM%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2011.5pt%3B%20%22%3E%3CSTRONG%3E%3CEM%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20else%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2011.5pt%3B%20%22%3E%3CSTRONG%3E%3CEM%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2011.5pt%3B%20%22%3E%3CSTRONG%3E%3CEM%3ELED4%E5%85%B3%E9%97%AD%EF%BC%9B%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2011.5pt%3B%20%22%3E%3CSTRONG%3E%3CEM%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2300b050%3B%20font-size%3A%2016.0pt%3B%22%3E%3CSTRONG%3E%E8%BD%AC%E6%8D%A2%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E4%B8%8B%E6%96%B9%E4%BC%A0%E9%80%81%E5%B8%A6%E7%A4%BA%E4%BE%8B%E6%9C%89%E4%B8%A4%E4%B8%AA%E8%BE%93%E5%85%A5%EF%BC%8C%E5%9D%87%E6%9D%A5%E8%87%AA%20ADC%20%E7%BB%93%E6%9E%9C%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%E5%9C%A8%E4%B8%8B%E4%B8%80%E4%B8%AA%E4%BB%A3%E7%A0%81%E6%B8%85%E5%8D%95%E4%B8%AD%EF%BC%8C%E8%BE%93%E5%85%A5%E5%80%BC%E7%BB%8F%E8%BF%87%E7%BC%A9%E6%94%BE%E5%B9%B6%E8%BD%AC%E6%8D%A2%E4%B8%BA%20LQ%20%E6%A0%BC%E5%BC%8F%E3%80%82%E8%BF%99%E4%BA%9B%E6%8E%A7%E5%88%B6%E5%9C%A8%E8%A7%86%E9%A2%91%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fvideo%2Fmotor-control-made-easy-with-kinetis-motor-suite%3AMOTOR-CONTROL-MADE-EASY-KMS%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%3E%E3%80%8AKinetis%20%E7%94%B5%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%85%A5%E9%97%A8%E3%80%8B%3C%2FSPAN%3E%3C%2FA%3E%E4%B8%AD%E7%9A%84%E4%BC%A0%E9%80%81%E5%B8%A6%E6%BC%94%E7%A4%BA%E4%B8%AD%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%BC%94%E7%A4%BA%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E3%80%82%E5%9B%BE%E4%B8%AD%E6%89%80%E7%A4%BA%E7%9A%84%E4%B8%A4%E4%B8%AA%E7%94%B5%E4%BD%8D%E5%99%A8%E8%A2%AB%E9%A6%88%E5%85%A5%20ADC%20%E9%80%9A%E9%81%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22conveyor_controls.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22conveyor_controls.png%22%20style%3D%22width%3A%20880px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F85632i1A6B6FA39005D4F3%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22conveyor_controls.png%22%20alt%3D%22conveyor_controls.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F*%E8%BD%AE%E8%AF%A2%E5%A4%96%E9%83%A8%E8%BE%93%E5%87%BA*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F*GPIO%20%E5%85%B7%E6%9C%89%20HW%20%E5%90%AF%E7%94%A8%E7%9A%84%E6%8A%97%E6%95%85%E9%9A%9C%E5%92%8C%E4%B8%8A%E6%8B%89%E5%8A%9F%E8%83%BD*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F*1%20%3D%20%E5%BC%80%E5%90%AF%200%20%3D%20%E5%85%B3%E9%97%AD%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%E7%94%A8%E6%88%B7%E8%AE%A1%E5%88%92%E5%8F%98%E9%87%8F.On_Off%3D%EF%BC%81%EF%BC%88%EF%BC%88bool%EF%BC%89GPIO_DRV_ReadPinInput%EF%BC%88kGpioOnOff%EF%BC%89%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F*%E9%AB%98%20%3D%201%EF%BC%8C%E4%BD%8E%20%3D%200%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%E7%94%A8%E6%88%B7%E8%AE%A1%E5%88%92%E5%8F%98%E9%87%8F.Low_High%3D(bool)GPIO_DRV_ReadPinInput(kGpioHighLow)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F*%E9%AB%98%E9%80%9F%E6%93%8D%E4%BD%9C%E9%9C%80%E8%A6%81%E7%A8%8D%E9%AB%98%E7%9A%84%E5%B8%A6%E5%AE%BD*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%E5%A6%82%E6%9E%9C%EF%BC%88userPlanVariables.Low_High%20%3D%3D%200%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%E7%94%A8%E6%88%B7%E8%AE%A1%E5%88%92%E5%8F%98%E9%87%8F.%E5%B8%A6%E5%AE%BD_%E9%AB%98%20%3D%20_LQ20(70.0)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%E7%94%A8%E6%88%B7%E8%AE%A1%E5%88%92%E5%8F%98%E9%87%8F.%E5%B8%A6%E5%AE%BD_%E4%BD%8E%20%3D%20_LQ20(10.0)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20else%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%E7%94%A8%E6%88%B7%E8%AE%A1%E5%88%92%E5%8F%98%E9%87%8F.%E5%B8%A6%E5%AE%BD_%E9%AB%98%20%3D%20_LQ20(100.0)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%E7%94%A8%E6%88%B7%E8%AE%A1%E5%88%92%E5%8F%98%E9%87%8F.%E5%B8%A6%E5%AE%BD_%E4%BD%8E%20%3D%20_LQ20(15.0)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20%23F5F2F0%3B%22%3E%3CSPAN%20style%3D%22color%3A%20slategray%3B%20font-size%3A%2011.5pt%3B%20%22%3E%3CSTRONG%3E%3CEM%3E%2F*%E5%80%BC%E6%8C%89%20LQ%20%E6%A0%BC%E5%BC%8F%20Q12-%26gt%3BGlobalLQ%20%E7%BC%A9%E6%94%BE%E5%88%B0%200-1*%2F%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2011.5pt%3B%20%22%3E%3CSTRONG%3E%3CEM%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E7%94%A8%E6%88%B7%E8%AE%A1%E5%88%92%E5%8F%98%E9%87%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E5%B8%A6%E5%AE%BD%E6%AF%94%E4%BE%8B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3E_LQXtoLQY%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Eadc0Results%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%5B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%5D%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E12%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3EGLOBAL_LQ%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E)%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%E4%BD%8D%E7%BD%AE%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.lq20Bw_radps%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3E_LQ20mpyLQX%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E7%94%A8%E6%88%B7%E8%AE%A1%E5%88%92%E5%8F%98%E9%87%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%E9%AB%98%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E5%B8%A6%E5%AE%BD%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E7%94%A8%E6%88%B7%E8%AE%A1%E5%88%92%E5%8F%98%E9%87%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E4%BD%8E%E5%B8%A6%E5%AE%BD%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E20U%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E7%94%A8%E6%88%B7%E8%AE%A1%E5%88%92%E5%8F%98%E9%87%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E5%B8%A6%E5%AE%BD%E6%AF%94%E4%BE%8B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3EGLOBAL_LQ%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%5C%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%2B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E7%94%A8%E6%88%B7%E8%AE%A1%E5%88%92%E5%8F%98%E9%87%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E5%B8%A6%E5%AE%BD_%E4%BD%8E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F*%20%E5%80%BC%E4%BB%A5%20LQ%20%E6%A0%BC%E5%BC%8F%E7%BC%A9%E6%94%BE%E5%88%B0%200-1%EF%BC%8C%E5%85%B7%E6%9C%89%E8%BD%BB%E6%8C%87%E6%95%B0%E6%9D%83%E9%87%8D%20.5821*(e%5Ex-1)*%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%E7%94%A8%E6%88%B7%E8%AE%A1%E5%88%92%E5%8F%98%E9%87%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3EJerk_Scale%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3E_LQmpy%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3E_LQXtoLQY%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3E_LQ20exp%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3E_LQXtoLQY%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Eadc1Results%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%5B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%5D%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E12%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E20U%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E))%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E20%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3EGLOBAL_LQ%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3E_LQ%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E1.0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E)%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%5C%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3E_LQ%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E0.581992%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%EF%BC%89%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%20background%3A%20white%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%20background%3A%20white%3B%22%3E%E6%82%A8%E4%B8%8D%E8%83%BD%E4%BB%85%E4%BB%85%E4%BD%BF%E7%94%A8%20RPM%20%E7%9A%84%E6%95%B4%E6%95%B0%E5%80%BC%E6%9D%A5%E8%AE%BE%E7%BD%AE%E7%9B%AE%E6%A0%87%E9%80%9F%E5%BA%A6%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%20background%3A%20white%3B%22%3E%E7%94%A8%E6%88%B7.%E5%91%BD%E4%BB%A4.%E7%9B%AE%E6%A0%87%E9%80%9F%E5%BA%A6%20%3D%20100%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3EKMS%20%E4%BB%A3%E7%A0%81%E5%9C%A8%E8%AE%A1%E7%AE%97%E4%B8%AD%E4%BD%BF%E7%94%A8%20QMath%E3%80%82%E4%BD%BF%E7%94%A8%20API%20%E8%B0%83%E7%94%A8%E5%8F%AF%E4%BB%A5%E8%BD%BB%E6%9D%BE%E5%9C%B0%E5%B0%86%E6%B5%AE%E7%82%B9%E6%95%B0%E6%88%96%E6%95%B4%E6%95%B0%E8%BD%AC%E6%8D%A2%E4%B8%BA%20LQ%20%E7%B1%BB%E5%9E%8B%E3%80%82%E6%9F%A5%E7%9C%8B%E7%AC%AC%2024%20%E7%AB%A0%E6%95%B0%E5%AD%A6%E4%BB%A5%E4%BA%86%E8%A7%A3%E6%9C%89%E5%85%B3%20QMath%20%E5%BA%93%E7%9A%84%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%20background%3A%20white%3B%22%3E%E5%9C%A8%20KMS%20%E4%B8%AD%EF%BC%8C%E6%89%80%E6%9C%89%E5%80%BC%E9%83%BD%E6%98%AF%E6%A0%87%E5%87%86%E5%8C%96%E5%AE%9A%E7%82%B9%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%B0%86%20user.command.targetSpeed%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%20100%20%E4%BC%9A%E5%B0%86%E7%9B%AE%E6%A0%87%E9%80%9F%E5%BA%A6%E8%AE%BE%E7%BD%AE%E4%B8%BA%E4%B8%80%E4%B8%AA%E9%9D%9E%E5%B8%B8%E5%B0%8F%E7%9A%84%E5%80%BC%EF%BC%88%26lt%3B%26lt%3B%201RPM%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%20background%3A%20white%3B%22%3E%E6%82%A8%E9%9C%80%E8%A6%81%E5%B0%86%20RPM%20%E8%BD%AC%E6%8D%A2%E4%B8%BA%20KMS%20%E4%BD%BF%E7%94%A8%E7%9A%84%E6%A0%87%E5%87%86%E5%8C%96%E5%AE%9A%E7%82%B9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%20background%3A%20white%3B%22%3E%E7%94%A8%E6%88%B7.%E5%91%BD%E4%BB%A4.%E7%9B%AE%E6%A0%87%E9%80%9F%E5%BA%A6%20%3D%20_LQ(100.0%2F%E5%85%A8%E9%80%9F%E8%BD%AC%E9%80%9F%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%20background%3A%20white%3B%22%3E%E5%9C%A8%E4%B8%8A%E4%B8%80%E8%A1%8C%E4%B8%AD%EF%BC%8CFULL_SCALE_SPEED_RPM%20%E8%A1%A8%E7%A4%BA%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8F%AF%E8%83%BD%E7%9A%84%E6%9C%80%E5%A4%A7%E9%80%9F%E5%BA%A6%E3%80%82%E5%B0%86%E8%BE%93%E5%85%A5%E9%80%9F%E5%BA%A6%20100.0%20%E9%99%A4%E4%BB%A5%E8%AF%A5%E5%80%BC%E5%B0%86%E6%8A%8A%E6%82%A8%E7%9A%84%E8%BE%93%E5%85%A5%E8%BD%AC%E6%8D%A2%E4%B8%BA%E6%A0%87%E5%87%86%E5%8C%96%E5%80%BC%E3%80%82%E7%94%B1%E4%BA%8EKMS%E4%B9%9F%E6%98%AF%E5%AE%9A%E7%82%B9%E6%95%B0%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E5%B0%86%E8%BF%99%E4%B8%AA%E8%A7%84%E8%8C%83%E5%8C%96%E7%9A%84%E6%B5%AE%E7%82%B9%E6%95%B0%E8%BD%AC%E6%8D%A2%E4%B8%BA%E5%AE%9A%E7%82%B9%E6%95%B0%E3%80%82%E5%AE%8F%20_LQ%20%E5%B0%86%E5%9C%A8%E9%BB%98%E8%AE%A4%20Qness%20%E4%B8%8B%E4%BB%8E%E6%B5%AE%E7%82%B9%E8%BD%AC%E6%8D%A2%E4%B8%BA%E5%AE%9A%E7%82%B9%E3%80%82%E5%8F%98%E9%87%8F%20user.command.targetSpeed%20%E8%A2%AB%E5%AE%9A%E4%B9%89%E4%B8%BA%20_lq%20%E5%8F%98%E9%87%8F%E3%80%82%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E5%AE%83%E6%98%AF%E4%B8%80%E4%B8%AA%2032%20%E4%BD%8D%E5%AE%B9%E5%99%A8%EF%BC%8CQness%20%E4%B8%BA%2024%EF%BC%88%E5%B0%8F%E6%95%B0%E7%82%B9%E5%90%8E%2024%20%E4%BD%8D%EF%BC%89%E3%80%82%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E6%89%80%E6%9C%89%20_lq%20%E5%8F%98%E9%87%8F%E9%83%BD%E9%BB%98%E8%AE%A4%E4%B8%BA%20Q24%EF%BC%8C%E9%99%A4%E9%9D%9E%E5%8F%98%E9%87%8F%E5%90%8D%E7%A7%B0%E5%8F%A6%E6%9C%89%E8%AF%B4%E6%98%8E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2300b050%3B%20font-size%3A%2016.0pt%3B%22%3E%3CSTRONG%3E%E6%8C%87%E6%8C%A5%E9%80%9F%E5%BA%A6%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%9C%A8%20KMS_API%20RM%20%E4%B8%AD%EF%BC%8C%E5%AE%9A%E4%B9%89%E4%BA%86%E7%94%A8%E6%88%B7%E5%9D%97%E3%80%82user.state%20%E5%AE%9A%E4%B9%89%E5%9C%A8%20user.h%20%E4%B8%AD%E6%96%87%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E6%83%B3%E8%AE%A9%E5%8F%91%E5%8A%A8%E6%9C%BA%E7%A9%BA%E8%BD%AC%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E8%BF%99%E6%A0%B7%E5%86%99%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E%E7%94%A8%E6%88%B7%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%230000c0%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%20color%3A%20%230000c0%3B%20font-size%3A%2012.0pt%3B%22%3E%3CEM%3EUSER_IDLE%3C%2FEM%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E8%A6%81%E5%B0%86%E7%94%A8%E6%88%B7%E7%8A%B6%E6%80%81%E8%AE%BE%E7%BD%AE%E4%B8%BA%E8%BF%90%E8%A1%8C%E9%80%9F%E5%BA%A6%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E8%BF%99%E6%A0%B7%E5%86%99%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E%E7%94%A8%E6%88%B7%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%230000c0%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%20color%3A%20%230000c0%3B%20font-size%3A%2012.0pt%3B%22%3E%3CEM%3EUSER_RUN_SPEED%3C%2FEM%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E8%BF%99%E6%98%AF%E7%94%A8%E4%BA%8E%E9%80%9F%E5%BA%A6%E6%8E%A7%E5%88%B6%E7%9A%84%E6%89%80%E6%9C%89%20USER_States%20%E7%9A%84%E5%88%97%E8%A1%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23F5F2F0%3B%20margin%3A%206.0pt%200in%206.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%3CBR%20%2F%3E%20*%20%40enum%20USER_state_e%3CBR%20%2F%3E%20*%20%40brief%20USER%20%E7%8A%B6%E6%80%81%E6%9C%BA%E7%8A%B6%E6%80%81%3CBR%20%2F%3E*%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%230077aa%3B%22%3Etypedef%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%230077aa%3B%22%3E%E6%9E%9A%E4%B8%BE%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%7B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EUSER_IDLE%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%200%3A%20%E7%94%A8%E6%88%B7%E7%A9%BA%E9%97%B2%E7%8A%B6%E6%80%81%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EUSER_FAULT%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%201%3A%20%E7%94%A8%E6%88%B7%E6%95%85%E9%9A%9C%E7%8A%B6%E6%80%81%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EUSER_SCM%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E2%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%202%3A%20USER%20%E8%87%AA%E8%B0%83%E8%AF%95%E7%8A%B6%E6%80%81%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EUSER_INERTIA%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%203%3A%20USER%20%E6%83%AF%E6%80%A7%E4%BC%B0%E8%AE%A1%E7%8A%B6%E6%80%81%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EUSER_RUN_DUTY%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E4%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%204%3A%20DSM%20%E8%BF%90%E8%A1%8C%20PWM%20%E5%8D%A0%E7%A9%BA%E6%AF%94%E6%8E%A7%E5%88%B6%E7%8A%B6%E6%80%81%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EUSER_RUN_VOLTAGE%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E5%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%205%3A%20DSM%20%E8%BF%90%E8%A1%8C%E7%94%B5%E5%8E%8B%E6%8E%A7%E5%88%B6%E7%8A%B6%E6%80%81%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EUSER_RUN_CURRENT%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E6%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%206%3A%20USER%20%E8%BF%90%E8%A1%8C%E5%BD%93%E5%89%8D%E6%8E%A7%E5%88%B6%E7%8A%B6%E6%80%81%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EUSER_RUN_SPEED%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E7%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%207%3A%20USER%20%E8%BF%90%E8%A1%8C%E9%80%9F%E5%BA%A6%E6%8E%A7%E5%88%B6%E7%8A%B6%E6%80%81%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EUSER_RUN_PLAN%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E8%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%208%3A%20USER%20%E8%BF%90%E8%A1%8C%E8%BF%90%E5%8A%A8%E8%AE%A1%E5%88%92%E7%8A%B6%E6%80%81%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EUSER_BRAKE%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E9%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%209%3A%20USER%20%E5%88%B6%E5%8A%A8%E7%8A%B6%E6%80%81%20*%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%7D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3EUSER_state_e%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BD%BF%E7%94%A8%20feedback_3ph.c%20%E4%BD%9C%E4%B8%BA%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%88%99%E4%BD%BF%E7%94%A8%E5%87%BD%E6%95%B0%20(_sq)%20%E5%B0%86%E5%8E%9F%E5%A7%8B%20ADC%20%E8%AF%BB%E6%95%B0%E8%BD%AC%E6%8D%A2%E4%B8%BA%20_sq%EF%BC%9AtempSQ%20%3D%20(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23005032%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E_sq%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E)(adcResults-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%230000c0%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3EphaseBCurrent%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E-%20v-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%230000c0%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3Ecalib%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%230000c0%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3EoffsetIb%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E%E5%90%8C%E6%A0%B7%EF%BC%8C%E4%BD%BF%E7%94%A8%20(_lq)%20%E5%87%BD%E6%95%B0%E5%8F%AF%E4%BB%A5%E5%B0%86%20RAW%20ADC%20%E7%BB%93%E6%9E%9C%E8%BD%AC%E6%8D%A2%E4%B8%BA%20LQ%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E%E5%9C%A8%E4%B8%8B%E9%9D%A2%E7%9A%84%E4%BB%A3%E7%A0%81%E7%A4%BA%E4%BE%8B%E4%B8%AD%EF%BC%8CADC%20%E8%BE%93%E5%85%A5%E7%94%A8%E4%BA%8E%E6%8E%A7%E5%88%B6%E9%80%9F%E5%BA%A6%E3%80%82%E4%B8%8B%E9%9D%A2%E7%9A%84%E4%BB%A3%E7%A0%81%E8%8E%B7%E5%8F%96%20ADC%20%E7%BB%93%E6%9E%9C%E5%B9%B6%E9%80%9A%E8%BF%87%E4%BB%A5%E4%B8%8B%E8%AF%AD%E5%8F%A5%E5%B0%86%E5%85%B6%E8%BD%AC%E6%8D%A2%E4%B8%BA%20_lq%20%E7%B1%BB%E5%9E%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3Eadc0%E7%BB%93%E6%9E%9C%5B0%5D%20%3D%20%EF%BC%88_lq%EF%BC%89adc0%E5%8E%9F%E5%A7%8B%E7%BB%93%E6%9E%9C%5B0%5D%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23F5F2F0%3B%20margin%3A%206.0pt%200in%206.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20slategray%3B%22%3E%2F*%20%E4%BB%A3%E7%A0%81%E5%BC%80%E5%A7%8B%20*%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20slategray%3B%22%3E%2F%2F%20%E5%9C%A8%20main.c%20%E4%B8%AD%E5%B0%86%E8%BF%99%E4%BA%9B%E5%A3%B0%E6%98%8E%E4%B8%BA%E5%85%A8%E5%B1%80%E5%8F%98%E9%87%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E_lq%20adcSpeed%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23990000%3B%22%3E0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E_lq%20adcSpeedAccum%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23990000%3B%22%3E0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E_lq%20adcSpeedAvg%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23990000%3B%22%3E0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3Euint16_t%20%E9%80%9F%E5%BA%A6%E6%9B%B4%E6%96%B0%E8%AE%A1%E6%95%B0%E5%99%A8%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23990000%3B%22%3E0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20slategray%3B%22%3E%2F%2F%20%E6%AD%A4%E4%BB%A3%E7%A0%81%E8%8E%B7%E5%8F%96%20ADC%20%E8%AF%BB%E6%95%B0%EF%BC%8C%E5%B0%86%E5%85%B6%E4%B8%8B%E7%A7%BB%204%20%E4%BB%A5%E6%B6%88%E9%99%A4%E5%99%AA%E9%9F%B3%EF%BC%8C%E5%B9%B6%E5%B0%86%E5%85%B6%E7%94%A8%E4%BD%9C%E6%9C%80%E5%A4%A7%E5%BA%94%E7%94%A8%E9%80%9F%E5%BA%A6%E7%9A%84%E7%99%BE%E5%88%86%E6%AF%94%EF%BC%88%E5%9C%A8%E6%9C%AC%E4%BE%8B%E4%B8%AD%E4%B8%BA%2020krpm%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EadcSpeed%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23d74444%3B%22%3E_LQmpyLQX%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3Eadc0Results%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%5B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23990000%3B%22%3E0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%5D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%26gt%3B%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23990000%3B%22%3E4%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E)%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23990000%3B%22%3E8%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23d74444%3B%22%3E_LQ%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23990000%3B%22%3E20000.0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%E6%BB%A1%E9%87%8F%E7%A8%8B%E9%80%9F%E5%BA%A6%20RPM%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E)%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23990000%3B%22%3E24%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EadcSpeed%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23d74444%3B%22%3E_LQsat%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3EadcSpeed%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%8C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23d74444%3B%22%3E_LQ%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23990000%3B%22%3E1.0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23d74444%3B%22%3E_LQ%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23990000%3B%22%3E0.0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20slategray%3B%22%3E%2F%2F%20%E6%AD%A4%E4%BB%A3%E7%A0%81%E5%9C%A8%E5%B0%86%20adc%20%E8%AF%BB%E6%95%B0%E8%AE%BE%E7%BD%AE%E4%B8%BA%20user.command.targetSpeed%20%E4%B9%8B%E5%89%8D%EF%BC%8C%E5%AF%B9%20125%20%E4%B8%AA%E6%A0%B7%E6%9C%AC%E8%BF%9B%E8%A1%8C%E5%B9%B3%E5%9D%87%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20slategray%3B%22%3E%2F%2F%20%E5%A6%82%E6%9E%9C%E5%91%BD%E4%BB%A4%E9%80%9F%E5%BA%A6%E5%A4%A7%E4%BA%8E%200%EF%BC%8C%E5%AE%83%E8%BF%98%E5%B0%86%E5%A4%84%E7%90%86%E8%AE%BE%E7%BD%AE%E6%8E%A7%E5%88%B6%E6%A8%A1%E5%BC%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%230077aa%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3EadcSpeed%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23d74444%3B%22%3E_LQ%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23990000%3B%22%3E0.0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%EF%BC%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%E7%94%A8%E6%88%B7%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3EUSER_RUN_SPEED%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%230077aa%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%E9%80%9F%E5%BA%A6%E6%9B%B4%E6%96%B0%E8%AE%A1%E6%95%B0%E5%99%A8%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%26gt%3B%20%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23990000%3B%22%3E125%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%E9%80%9F%E5%BA%A6%E6%9B%B4%E6%96%B0%E8%AE%A1%E6%95%B0%E5%99%A8%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23990000%3B%22%3E0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EadcSpeedAvg%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3EadcSpeedAccum%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23990000%3B%22%3E125%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23990000%3B%22%3E0x00FF0000%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%E7%94%A8%E6%88%B7%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E.targetSpeed%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3EadcSpeedAvg%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%E2%80%8B%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3Eadc%E9%80%9F%E5%BA%A6%E7%B4%AF%E5%8A%A0%E5%99%A8%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23990000%3B%22%3E0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%230077aa%3B%22%3E%E5%88%AB%E7%9A%84%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%7B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3Eadc%E9%80%9F%E5%BA%A6%E7%B4%AF%E5%8A%A0%E5%99%A8%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3Eadc%E9%80%9F%E5%BA%A6%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%2B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3Eadc%E9%80%9F%E5%BA%A6%E7%B4%AF%E5%8A%A0%E5%99%A8%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%E9%80%9F%E5%BA%A6%E6%9B%B4%E6%96%B0%E8%AE%A1%E6%95%B0%E5%99%A8%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%2B%2B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%230077aa%3B%22%3E%E5%88%AB%E7%9A%84%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%E7%94%A8%E6%88%B7%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3EUSER_IDLE%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3Eadc%E9%80%9F%E5%BA%A6%E7%B4%AF%E5%8A%A0%E5%99%A8%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23990000%3B%22%3E0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3Eadc%E9%80%9F%E5%BA%A6%E5%B9%B3%E5%9D%87%E5%80%BC%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23990000%3B%22%3E0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%E9%80%9F%E5%BA%A6%E6%9B%B4%E6%96%B0%E8%AE%A1%E6%95%B0%E5%99%A8%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23990000%3B%22%3E0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23999999%3B%22%3E%7D%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2300b050%3B%20font-size%3A%2016.0pt%3B%22%3E%3CSTRONG%3E%E8%AE%BE%E7%BD%AE%E5%91%BD%E4%BB%A4%E5%80%BC%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%9C%A8%E6%9B%B4%E6%94%B9%E7%94%A8%E6%88%B7%E7%8A%B6%E6%80%81%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BF%AE%E6%94%B9%E5%8A%A0%E9%80%9F%E5%BA%A6%E5%92%8C%E5%8A%A0%E9%80%9F%E5%BA%A6%E7%AD%89%E5%8F%82%E6%95%B0%E3%80%82%E5%9C%A8%E6%94%B9%E5%8F%98%E7%8A%B6%E6%80%81%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E4%B8%8B%E9%9D%A2%E7%9A%84%E5%87%BD%E6%95%B0%E4%B8%AD%E6%9B%B4%E6%96%B0%E4%BB%BB%E6%84%8F%E6%95%B0%E9%87%8F%E7%9A%84%E5%85%B6%E4%BB%96%E5%91%BD%E4%BB%A4%E5%80%BC%E5%88%97%E8%A1%A8%E3%80%82%E8%AF%A5%E5%88%97%E8%A1%A8%E5%8F%AF%E8%AE%A9%E6%82%A8%E5%BF%AB%E9%80%9F%E6%9F%A5%E7%9C%8B%E5%9C%A8%E6%94%B9%E5%8F%98%E7%94%B5%E6%9C%BA%E7%8A%B6%E6%80%81%E4%B9%8B%E5%89%8D%E5%8F%AF%E4%BB%A5%E6%9B%B4%E6%96%B0%E7%9A%84%E5%8F%82%E6%95%B0%E3%80%82%E5%88%97%E5%87%BA%E7%9A%84%E6%AF%8F%E4%B8%AA%E5%91%BD%E4%BB%A4%E5%80%BC%E9%83%BD%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%AD%A4%E8%B0%83%E7%94%A8%E4%B9%8B%E5%89%8D%E6%9B%B4%E6%96%B0%E3%80%82%E5%A6%82%E6%82%A8%E6%89%80%E8%A7%81%EF%BC%8C%E5%9C%A8%E5%8C%85%E5%90%AB%20command.targetSpeed%20%E7%9A%84%E8%A1%8C%E4%B8%AD%E8%AE%BE%E7%BD%AE%E9%80%9F%E5%BA%A6%E5%80%BC%E5%8F%AA%E6%98%AF%E5%8F%91%E9%80%81%E7%BB%99%E9%A9%B1%E5%8A%A8%E5%91%BD%E4%BB%A4%E7%9A%84%E4%BA%94%E4%B8%AA%E5%80%BC%E4%B9%8B%E4%B8%80%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E8%AE%BE%E7%BD%AE%E8%BF%99%E4%BA%9B%E5%8F%82%E6%95%B0%E5%90%8E%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%91%BD%E4%BB%A4%E7%8A%B6%E6%80%81%E6%9B%B4%E6%94%B9%E4%B8%BA%20USER_RUN_SPEED%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E%E7%94%A8%E6%88%B7%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%230000c0%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%20color%3A%20%230000c0%3B%20font-size%3A%2012.0pt%3B%22%3E%3CEM%3EUSER_RUN_SPEED%3C%2FEM%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E7%94%A8%E6%88%B7%E7%8A%B6%E6%80%81%E2%80%9CUSER_RUN_SPEED%E2%80%9D%E6%89%A7%E8%A1%8C%E6%AD%A4%E5%8A%9F%E8%83%BD%EF%BC%8C%E4%BB%A5%E6%96%B0%E7%9A%84%E8%BD%A8%E8%BF%B9%E5%90%AF%E5%8A%A8%E7%94%B5%E6%9C%BA%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23F5F2F0%3B%20margin%3A%206.0pt%200in%206.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%3CBR%20%2F%3E%20*%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F233122%22%3E%40FN%3C%2Fa%3E%20USER_runSpeedState(USER_t%20*pUSER%2C%20SPEED_t%20*speed%2C%20DRV_control_e%20controlType%2C%20%5C%3CBR%20%2F%3E%20*%20TRF_rVector16_t%20startupStatorRefCurrent%EF%BC%8C_sq%20fwIdRef%EF%BC%89%3CBR%20%2F%3E%20*%20%40brief%20%E8%BF%90%E8%A1%8C%E9%80%9F%E5%BA%A6%E6%8E%A7%E5%88%B6%E7%94%A8%E6%88%B7%E7%8A%B6%E6%80%81%3CBR%20%2F%3E*%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F197964%22%3E%40Param%3C%2Fa%3E%20pUSER%20-%20%E6%8C%87%E5%90%91%20USER%20%E5%9D%97%E7%9A%84%E6%8C%87%E9%92%88%3CBR%20%2F%3E*%20%40return%20%E6%97%A0%3CBR%20%2F%3E*%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%230077aa%3B%22%3E%E9%9D%99%E6%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%230077aa%3B%22%3Evoid%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3EUSER_runSpeedState%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3EUSER_t%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E*%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3EpUSER%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F*%20%E5%AF%B9%E4%BA%8E%E8%BD%A8%E8%BF%B9%EF%BC%8C%E5%8F%AA%E9%9C%80%E5%B0%86%E5%91%BD%E4%BB%A4%E5%80%BC%E5%8F%91%E9%80%81%E5%88%B0%20DRV%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.drvCommand.targetSpeed%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.targetSpeed%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%E2%80%8B%E2%80%8B%E2%80%8B%E2%80%8B%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.drvCommand.limitAcc%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.limitAcc%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%E2%80%8B%E2%80%8B%E2%80%8B%E2%80%8B%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EpUSER%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E9%A9%B1%E5%8A%A8%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Elq20LimitJerk%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3EpUSER%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%E3%80%82%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Elq20%E9%99%90%E5%88%B6%E5%8A%A0%E5%8A%A0%E9%80%9F%E5%BA%A6%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.drvCommand.IqRefMax%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.IqRefMax%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%E2%80%8B%E2%80%8B%E2%80%8B%E2%80%8B%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.drvCommand.IqRefMin%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E.IqRefMin%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%E2%80%8B%E2%80%8B%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F*%20%E5%9C%A8%E6%AD%A4%E7%8A%B6%E6%80%81%E4%B8%8B%E8%BF%90%E8%A1%8C%E8%BD%A8%E8%BF%B9%E7%94%9F%E6%88%90%E5%99%A8%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EpUSER%3C%2FSPAN%3E%20-%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.drvCommand.runTrajectory%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Etrue%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%E2%80%8B%E2%80%8B%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%230077aa%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%7D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F*%20USER_runSpeedState()%20%E7%BB%93%E6%9D%9F%20*%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20green%3B%20font-size%3A%2016.5pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2300b050%3B%20font-size%3A%2016.0pt%3B%22%3E%3CSTRONG%3E%E6%8C%87%E4%BB%A4%E6%89%AD%E7%9F%A9%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E8%A6%81%E6%8E%A7%E5%88%B6%E6%89%AD%E7%9F%A9%EF%BC%88%E7%94%B5%E6%B5%81%EF%BC%89%EF%BC%8C%E9%82%A3%E4%B9%88%E6%82%A8%E5%B0%86%E5%88%9D%E5%A7%8B%E5%8C%96%E4%B8%8B%E9%9D%A2%E4%BB%A3%E7%A0%81%E4%B8%AD%E6%A0%87%E8%AF%86%E7%9A%84%E5%91%BD%E4%BB%A4%E5%80%BC%E3%80%82%E9%99%A4%E4%BA%86%E5%91%BD%E4%BB%A4%20.statorRefCurrent%20%E4%B9%8B%E5%A4%96%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%8C%87%E5%AE%9A%E4%B8%80%E4%B8%AA%20command.targetSpeed%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23F5F2F0%3B%20margin%3A%206.0pt%200in%206.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20slategray%3B%22%3E%2F**%3CBR%20%2F%3E%20*%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F233122%22%3E%40FN%3C%2Fa%3E%20USER_runCurrentState%EF%BC%88USER_t%20*pUSER%EF%BC%89%3CBR%20%2F%3E%20*%20%40brief%20%E8%BF%90%E8%A1%8C%E5%BD%93%E5%89%8D%E6%8E%A7%E5%88%B6%E7%94%A8%E6%88%B7%E7%8A%B6%E6%80%81%3CBR%20%2F%3E*%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F197964%22%3E%40Param%3C%2Fa%3E%20pUSER%20-%20%E6%8C%87%E5%90%91%20USER%20%E5%9D%97%E7%9A%84%E6%8C%87%E9%92%88%3CBR%20%2F%3E*%20%40return%20%E6%97%A0%3CBR%20%2F%3E*%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%230077aa%3B%22%3E%E9%9D%99%E6%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%230077aa%3B%22%3Evoid%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23d74444%3B%22%3EUSER_runCurrentState%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3EUSER_t%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23a67f59%3B%22%3E*%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3EpUSER%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E%7B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E.drvCommand.targetSpeed%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E.targetSpeed%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%E2%80%8B%E2%80%8B%E2%80%8B%E2%80%8B%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E.drvCommand.limitAcc%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E.limitAcc%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%E2%80%8B%E2%80%8B%E2%80%8B%E2%80%8B%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EpUSER%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23a67f59%3B%22%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E9%A9%B1%E5%8A%A8%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3Elq20LimitJerk%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3EpUSER%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23a67f59%3B%22%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E%E3%80%82%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3Elq20%E9%99%90%E5%88%B6%E5%8A%A0%E5%8A%A0%E9%80%9F%E5%BA%A6%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E.drvCommand%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E5%AE%9A%E5%AD%90%E5%8F%82%E8%80%83%E7%94%B5%E6%B5%81%3C%2FSPAN%3E%3D%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23a67f59%3B%22%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E%E5%AE%9A%E5%AD%90%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E5%8F%82%E8%80%83%E7%94%B5%E6%B5%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E.drvCommand.enableDCInjection%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E.enableDCInjection%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%E2%80%8B%E2%80%8B%E2%80%8B%E2%80%8B%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%230077aa%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23999999%3B%22%3E%7D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20slategray%3B%22%3E%2F*%20USER_runCurrentState()%20%E7%BB%93%E6%9D%9F%20*%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2300b050%3B%20font-size%3A%2016.0pt%3B%22%3E%3CSTRONG%3E%E6%8C%87%E6%8C%A5%E8%81%8C%E4%BD%8D%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%BD%93%E4%BD%BF%E7%94%A8KMS%E6%8E%A7%E5%88%B6%E4%BB%93%E4%BD%8D%E6%97%B6%EF%BC%8C%E4%BC%9A%E8%B0%83%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%87%BD%E6%95%B0%E3%80%82%E9%80%9A%E8%BF%87%E5%B0%86%E5%91%BD%E4%BB%A4%E5%80%BC%E8%AE%BE%E7%BD%AE%E4%B8%BA%E7%94%B5%E6%9C%BA%E9%A9%B1%E5%8A%A8%E7%8A%B6%E6%80%81%E6%9C%BA%EF%BC%8C%E7%94%B5%E6%9C%BA%E4%BD%8D%E7%BD%AE%E6%8E%A7%E5%88%B6%E5%B0%86%E9%81%B5%E5%BE%AA%E6%82%A8%E5%9C%A8%E8%B0%83%E7%94%A8%E4%B9%8B%E5%89%8D%E9%80%89%E6%8B%A9%E7%9A%84%E8%BD%A8%E8%BF%B9%E3%80%82%E5%9C%A8%E4%BD%8D%E7%BD%AE%E6%8E%A7%E5%88%B6%E5%8F%82%E8%80%83%E9%A1%B9%E7%9B%AE%E4%B8%AD%E5%8C%85%E5%90%AB%E6%96%87%E4%BB%B6%E2%80%9Cuser.h%E2%80%9DUSER_STATES%20-%26gt%3B%20USER_RUN_POSITION%20%E5%92%8C%20USER_ALIGN%20%E5%88%97%E8%A1%A8%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%BA%86%E4%B8%A4%E4%B8%AA%20USER%20%E7%8A%B6%E6%80%81%E6%9C%BA%E7%8A%B6%E6%80%81%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23F5F2F0%3B%20margin%3A%206.0pt%200in%206.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%3CBR%20%2F%3E%20*%20%40enum%20USER_state_e%3CBR%20%2F%3E%20*%20%40brief%20USER%20%E7%8A%B6%E6%80%81%E6%9C%BA%E7%8A%B6%E6%80%81%3CBR%20%2F%3E*%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%230077aa%3B%22%3Etypedef%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%230077aa%3B%22%3E%E6%9E%9A%E4%B8%BE%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%7B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EUSER_IDLE%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%200%3A%20%E7%94%A8%E6%88%B7%E7%A9%BA%E9%97%B2%E7%8A%B6%E6%80%81%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EUSER_FAULT%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%201%3A%20%E7%94%A8%E6%88%B7%E6%95%85%E9%9A%9C%E7%8A%B6%E6%80%81%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EUSER_SCM%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E2%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%202%3A%20USER%20%E8%87%AA%E8%B0%83%E8%AF%95%E7%8A%B6%E6%80%81%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EUSER_INERTIA%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%203%3A%20USER%20%E6%83%AF%E6%80%A7%E4%BC%B0%E8%AE%A1%E7%8A%B6%E6%80%81%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EUSER_RUN_DUTY%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E4%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%204%3A%20DSM%20%E8%BF%90%E8%A1%8C%20PWM%20%E5%8D%A0%E7%A9%BA%E6%AF%94%E6%8E%A7%E5%88%B6%E7%8A%B6%E6%80%81%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EUSER_RUN_VOLTAGE%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E5%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%205%3A%20DSM%20%E8%BF%90%E8%A1%8C%E7%94%B5%E5%8E%8B%E6%8E%A7%E5%88%B6%E7%8A%B6%E6%80%81%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EUSER_RUN_CURRENT%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E6%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%206%3A%20USER%20%E8%BF%90%E8%A1%8C%E5%BD%93%E5%89%8D%E6%8E%A7%E5%88%B6%E7%8A%B6%E6%80%81%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EUSER_RUN_SPEED%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E7%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%207%3A%20USER%20%E8%BF%90%E8%A1%8C%E4%BD%8D%E7%BD%AE%E6%8E%A7%E5%88%B6%E9%80%9F%E5%BA%A6%E7%8A%B6%E6%80%81%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EUSER_RUN_PLAN%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E8%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%208%3A%20USER%20%E8%BF%90%E8%A1%8C%E8%BF%90%E5%8A%A8%E8%AE%A1%E5%88%92%E7%8A%B6%E6%80%81%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EUSER_BRAKE%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E9%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%209%3A%20USER%20%E5%88%B6%E5%8A%A8%E7%8A%B6%E6%80%81%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EUSER_RUN_POSITION%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E10%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%2010%3A%20USER%20%E8%BF%90%E8%A1%8C%E4%BD%8D%E7%BD%AE%E6%8E%A7%E5%88%B6%E7%8A%B6%E6%80%81%20*%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%E7%94%A8%E6%88%B7%E5%AF%B9%E9%BD%90%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E11%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F**%26lt%3B%2011%EF%BC%9A%E7%94%A8%E6%88%B7%E5%BC%BA%E5%88%B6%E7%94%B5%E6%9C%BA%E5%AF%B9%E5%87%86%20*%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E7%94%A8%E6%88%B7%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E8%A6%81%E5%91%BD%E4%BB%A4%E4%BD%8D%E7%BD%AE%EF%BC%8C%E8%AF%B7%E8%AE%BE%E7%BD%AE%E5%91%BD%E4%BB%A4%E5%80%BC%EF%BC%8C%E7%84%B6%E5%90%8E%E5%B0%86%E7%8A%B6%E6%80%81%E8%AE%BE%E7%BD%AE%E4%B8%BA%20USER_RUN_POSITION%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E%E7%94%A8%E6%88%B7%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%230000c0%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%20color%3A%20%230000c0%3B%20font-size%3A%2012.0pt%3B%22%3E%3CEM%3EUSER_RUN_POSITION%3C%2FEM%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%20border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%22%3E%E8%BF%99%E5%B0%86%E4%BA%A7%E7%94%9F%E4%B8%80%E6%9D%A1%E8%A6%81%E6%89%A7%E8%A1%8C%E7%9A%84%E8%BD%A8%E8%BF%B9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23F5F2F0%3B%20margin%3A%206.0pt%200in%206.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22color%3A%20slategray%3B%22%3E%2F**%3CBR%20%2F%3E%20*%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F233122%22%3E%40FN%3C%2Fa%3E%20USER%20runSpeedState(USER_t%20*pUSER%2CSPEED_t%20*speed%2CDRV_control_e%20controlType%2C%3CBR%20%2F%3E%20*%20TRF_rVector16_t%20startupStatorRefCurrent%EF%BC%8C_sq%20fwIdRef%EF%BC%89%3CBR%20%2F%3E%20*%20%40brief%20%E8%BF%90%E8%A1%8C%E9%80%9F%E5%BA%A6%E6%8E%A7%E5%88%B6%E7%94%A8%E6%88%B7%E7%8A%B6%E6%80%81%3CBR%20%2F%3E*%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F197964%22%3E%40Param%3C%2Fa%3E%20pUSER%20-%20%E6%8C%87%E5%90%91%20USER%20%E5%9D%97%E7%9A%84%E6%8C%87%E9%92%88%3CBR%20%2F%3E*%20%40return%20%E6%97%A0%3CBR%20%2F%3E*%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%230077aa%3B%22%3E%E9%9D%99%E6%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%230077aa%3B%22%3Evoid%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23d74444%3B%22%3EUSER_runPositionState%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EUSER_t%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E*%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EpUSER%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%EF%BC%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20slategray%3B%22%3E%2F*%20%E5%AF%B9%E4%BA%8E%E8%BD%A8%E8%BF%B9%EF%BC%8C%E5%8F%AA%E9%9C%80%E5%B0%86%E5%91%BD%E4%BB%A4%E5%80%BC%E5%8F%91%E9%80%81%E5%88%B0%20DRV%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CBR%20%2F%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E.drvCommand.runTrajectory%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E.runTrajectory%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%E2%80%8B%E2%80%8B%E2%80%8B%E2%80%8B%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CBR%20%2F%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E.drvCommand.posStepInt_mrev%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E.posStepInt_mrev%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%E2%80%8B%E2%80%8B%E2%80%8B%E2%80%8B%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CBR%20%2F%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E.drvCommand.posStepFrac_mrev%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E.posStepFrac_mrev%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%E2%80%8B%E2%80%8B%E2%80%8B%E2%80%8B%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CBR%20%2F%3EpUSER%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EdrvCommand%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3ElimitVel%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EpUSER%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3ElimitVel%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CBR%20%2F%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E.drvCommand.limitAcc%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E.limitAcc%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%E2%80%8B%E2%80%8B%E2%80%8B%E2%80%8B%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CBR%20%2F%3EpUSER%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EdrvCommand%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3ElimitDec%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EpUSER%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3ElimitDec%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CBR%20%2F%3EpUSER%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E9%A9%B1%E5%8A%A8%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Elq20LimitJerk%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EpUSER%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E-%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%E3%80%82%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Elq20%E9%99%90%E5%88%B6%E5%8A%A0%E5%8A%A0%E9%80%9F%E5%BA%A6%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CBR%20%2F%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E.drvCommand.IqRefMax%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E.IqRefMax%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%E2%80%8B%E2%80%8B%E2%80%8B%E2%80%8B%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CBR%20%2F%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E.drvCommand.IqRefMin%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EpUSER-%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%E2%80%8B%E2%80%8B%E2%80%8B%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E5%8F%82%E8%80%83%E6%99%BA%E5%95%86%E6%9C%80%E4%BD%8E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20slategray%3B%22%3E%2F*%20%E4%BB%A5%E4%BD%8D%E7%BD%AE%E6%A8%A1%E5%BC%8F%E8%BF%90%E8%A1%8C%E8%BD%A8%E8%BF%B9%E7%94%9F%E6%88%90%E5%99%A8%20*%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CBR%20%2F%3EpUSER%3C%2FSPAN%3E%20-%20%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E.drvCommand.velocityMode%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Efalse%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23a67f59%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%E2%80%8B%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%230077aa%3B%22%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23999999%3B%22%3E%7D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20slategray%3B%22%3E%2F*%20USER_runSpeedState()%20%E7%BB%93%E6%9D%9F%20*%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E7%94%A8%E4%BA%8E%E9%A9%B1%E5%8A%A8%E4%BD%8D%E7%BD%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E7%9A%84%20X%20%E8%BD%B4%E6%88%96%20Y%20%E8%BD%B4%E7%9A%84%E8%A3%B8%E6%9C%BA%E4%BB%A3%E7%A0%81%E7%A4%BA%E4%BE%8B%E3%80%82UART%20%E6%8E%A5%E6%94%B6%E5%91%BD%E4%BB%A4%EF%BC%8CGPIO%20%E4%B8%8A%E7%9A%84%E5%90%8C%E6%AD%A5%E8%84%89%E5%86%B2%E5%90%AF%E5%8A%A8%E8%BD%A8%E8%BF%B9%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E3%80%82%E7%94%B1%E4%BA%8E%E5%91%BD%E4%BB%A4%E6%A0%BC%E5%BC%8F%E6%A3%80%E6%9F%A5%E5%BE%88%E5%B0%91%EF%BC%8C%E5%9B%A0%E6%AD%A4%E8%BF%99%E4%B8%8D%E6%98%AF%E9%9D%9E%E5%B8%B8%E5%BC%BA%E5%A4%A7%E7%9A%84%E4%BB%A3%E7%A0%81%E3%80%82%E6%88%91%E9%BC%93%E5%8A%B1%E6%82%A8%E5%9C%A8%E4%BD%BF%E7%94%A8%E8%BE%93%E5%85%A5%E5%91%BD%E4%BB%A4%E5%80%BC%E6%9D%A5%E6%8E%A7%E5%88%B6%E7%94%B5%E6%9C%BA%E4%BD%8D%E7%BD%AE%E4%B9%8B%E5%89%8D%E8%80%83%E8%99%91%E5%85%B6%E6%9E%81%E9%99%90%E6%9D%A1%E4%BB%B6%E5%92%8C%E6%AD%A3%E7%A1%AE%E6%80%A7%E3%80%82%E6%AD%A4%E4%BB%A3%E7%A0%81%E5%81%B6%E5%B0%94%E4%BC%9A%E5%A4%B1%E8%B4%A5%EF%BC%8C%E5%B9%B6%E5%AF%BC%E8%87%B4%203D%20%E6%89%93%E5%8D%B0%E6%9C%BA%E5%BA%95%E5%BA%A7%E9%A3%9E%E5%88%B0%E6%9C%AB%E7%AB%AF%E5%81%9C%E6%AD%A2%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20%23F5F2F0%3B%20margin%3A%206.0pt%200in%206.0pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E7%94%A8%E6%88%B7%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3EUSER_RUN_POSITION%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%230077aa%3B%22%3Ewhile%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E7%9C%9F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F%2F%20LED2%20%E7%BB%BF%E8%89%B2%E4%B8%BA%E7%9B%B4%E6%B5%81%E6%AF%8D%E7%BA%BF%E5%85%85%E7%94%B5%E6%8C%87%E7%A4%BA%E7%81%AF%EF%BC%8C%E8%8B%A5%E5%8F%91%E7%94%9F%E6%95%85%E9%9A%9C%E5%88%99%E7%A6%81%E7%94%A8%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%230077aa%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3EDRV_getDcbBusVoltage%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3EDRV_getDcbBusUnderVoltageThreshold%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%7C%7C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3EDRV_getIsFaultActive%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%EF%BC%89%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3ELED2_OFF%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%230077aa%3B%22%3E%E5%90%A6%E5%88%99%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3ELED2_ON%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F%2F%20%E9%A2%84%E6%9C%9F%E6%A0%BC%E5%BC%8F%EF%BC%9AxAAAAAAAABBBBBBBBX%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F%2F%20%E7%AD%89%E5%BE%85%E5%88%9D%E5%A7%8B%E2%80%9Cx%E2%80%9D%E6%88%96%E2%80%9Cy%E2%80%9D%EF%BC%8C%E8%AE%B0%E5%BE%97%E5%9C%A8%E8%BD%B4%E5%8F%98%E9%87%8F%E4%B8%AD%E8%AE%BE%E7%BD%AE%E5%AE%83%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EGPIOC_PSOR%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F%2F%E8%AE%BE%E7%BD%AE%E7%BC%93%E5%86%B2%E5%8C%BA%E5%B0%B1%E7%BB%AA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%230077aa%3B%22%3E%E6%89%A7%E8%A1%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%7B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Ecin%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3EUART1_CharIn%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E()%3B%7D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%230077aa%3B%22%3Ewhile%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Ecin%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E!%3C%2FSPAN%3E%3D%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E8%BD%B4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F%2F%20%E8%AF%BB%E5%8F%96%20AAAAAAAA%EF%BC%88dx%20%E4%BD%9C%E4%B8%BA%E6%B5%AE%E7%82%B9%E6%95%B0%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3Emem%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E*%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%EF%BC%86%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Ef1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%230077aa%3B%22%3E%E5%AF%B9%E4%BA%8E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Ei%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Ei%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E4%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Ei%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%2B%2B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%7B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E*%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Emem%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3EUART1_ByteIn%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%EF%BC%89%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Emem%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%2B%2B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3B%7D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F%2F%20%E8%AF%BB%E5%8F%96%20BBBBBBBB%EF%BC%88dy%20%E4%BD%9C%E4%B8%BA%E6%B5%AE%E7%82%B9%E6%95%B0%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3Emem%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E*%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%EF%BC%86%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Ef2%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%230077aa%3B%22%3E%E5%AF%B9%E4%BA%8E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Ei%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Ei%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E4%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Ei%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%2B%2B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%7B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E*%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Emem%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3EUART1_ByteIn%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%EF%BC%89%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Emem%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%2B%2B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3B%7D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F%2F%20%E7%AD%89%E5%BE%85%E6%9C%80%E7%BB%88%E7%9A%84%E2%80%9CX%E2%80%9D%E6%88%96%E2%80%9CY%E2%80%9D%EF%BC%9A%E5%A6%82%E6%9E%9C%E4%B8%8D%E6%98%AF%E2%80%9CX%E2%80%9D%E6%88%96%E2%80%9CY%E2%80%9D%EF%BC%8C%E5%88%99%E5%BF%BD%E7%95%A5%E6%B6%88%E6%81%AF%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3Ecin%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3EUART1_CharIn%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%230077aa%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Ecin%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E8%BD%B4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E-32%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%7B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EGPIOC_PCOR%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E)%20%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3EUART_CharOut%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E8%BD%B4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F%2F%20%E6%9C%89%E6%95%88%E6%B6%88%E6%81%AF%EF%BC%8C%E7%BB%A7%E7%BB%AD%E6%89%A7%E8%A1%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F%2F%20ROTATION%EF%BC%9A%E6%8F%90%E5%8F%96%E6%97%8B%E8%BD%AC%E7%9A%84%E6%95%B4%E6%95%B0%E9%83%A8%E5%88%86%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%E5%80%BC%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%230077aa%3B%22%3Eint%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Ef1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%E7%94%A8%E6%88%B7%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.posStepInt_mrev%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E5%80%BC%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%E2%80%8B%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F%2FUART_TextOut(%22IntRotation%3D%22)%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3EUART_DbleOut%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E5%80%BC%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%8C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E4%EF%BC%8C1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F%2F%20ROTATION%EF%BC%9A%E6%8F%90%E5%8F%96%E6%97%8B%E8%BD%AC%E7%9A%84%E5%B0%8F%E6%95%B0%E9%83%A8%E5%88%86%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%E7%94%A8%E6%88%B7%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3EposStepFrac_mrev%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3E_LQ%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Ef1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E5%80%BC%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F%2FUART_TextOut(%22FracRotation%3D%22)%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3EUART_DbleOut%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Ef1-%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%E5%80%BC%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%8C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E4%EF%BC%8C4%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%E2%80%8B%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F%2F%20SPEED%EF%BC%9A%E6%8F%90%E5%8F%96%E6%97%8B%E8%BD%AC%E7%9A%84%E6%95%B4%E6%95%B0%E9%83%A8%E5%88%86%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3Ef2%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Ef2%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E4000.0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%E7%94%A8%E6%88%B7%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.limitVel%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3E_LQ%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Ef2%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E)%3C%2FSPAN%3E%20%EF%BC%9B%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F%2FUART_TextOut(%22%E9%80%9F%E5%BA%A6RPM%3D%22)%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3EUART_DbleOut%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Ef2%EF%BC%8C4%EF%BC%8C4%3C%2FSPAN%3E%20%EF%BC%89%20%EF%BC%9B%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EGPIOC_PSOR%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E6%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E)%20%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F%2F%20%E7%AD%89%E5%BE%85%E5%90%8C%E6%AD%A5%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%230077aa%3B%22%3E%E8%80%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%EF%BC%88%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3EGPIOE_PDIR%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E6%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%EF%BC%89%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%EF%BC%89%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EGPIOC_PCOR%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E6%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E)%20%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%E6%A0%87%E5%BF%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E0%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E5%AE%8C%E6%88%90%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E7%94%A8%E6%88%B7%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E5%91%BD%E4%BB%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%E8%BF%90%E8%A1%8C%E8%BD%A8%E8%BF%B9%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%230077aa%3B%22%3Ewhile%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3Edone%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E)%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%7B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23d74444%3B%22%3EUART_CharOut%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23669900%3B%22%3E'1'%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E)%3B%7D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3EGPIOC_PSOR%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23a67f59%3B%22%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23990000%3B%22%3E6%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E)%20%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23999999%3B%22%3E%7D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20slategray%3B%22%3E%2F%2Fwhile%20(true%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20black%3B%22%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2300b050%3B%20font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%E7%BB%93%E8%AE%BA%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E9%9C%80%E8%A6%81%E5%9B%9B%E4%B8%AA%E6%AD%A5%E9%AA%A4%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3COL%3E%3CLI%3E%E6%A3%80%E6%9F%A5%E7%94%B5%E6%9C%BA%E7%9A%84%E7%8E%B0%E6%9C%89%E7%8A%B6%E6%80%81%E3%80%81%E7%AE%A1%E7%90%86%E6%95%85%E9%9A%9C%E5%92%8C%E8%BD%A8%E8%BF%B9%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%B0%86%E5%91%BD%E4%BB%A4%E8%BE%93%E5%85%A5%E8%BD%AC%E6%8D%A2%E4%B8%BA%20KMS%20%E6%89%80%E9%9C%80%E7%9A%84%E5%AE%9A%E7%82%B9%E5%80%BC%E3%80%82%3C%2FLI%3E%3CLI%3E%E8%AE%BE%E7%BD%AE%E9%85%8D%E7%BD%AE%E5%8F%82%E6%95%B0%EF%BC%8C%E5%A6%82%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%80%81%E5%8A%A0%E5%8A%A0%E9%80%9F%E5%BA%A6%E5%92%8C%E9%80%9F%E5%BA%A6%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%B0%86%E7%94%A8%E6%88%B7%E7%8A%B6%E6%80%81%E6%9B%B4%E6%94%B9%E4%B8%BA%E6%89%80%E9%9C%80%E7%8A%B6%E6%80%81%EF%BC%8C%E9%80%9F%E5%BA%A6%E3%80%81%E6%89%AD%E7%9F%A9%E3%80%81%E4%BD%8D%E7%BD%AE%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E8%8F%B2%E5%88%A9%E6%99%AE%C2%B7%E5%BE%B7%E9%9B%B7%E5%85%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%233d3d3d%3B%22%3E%E7%B3%BB%E7%BB%9F%E5%BA%94%E7%94%A8%E5%B7%A5%E7%A8%8B%E5%B8%88%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1108011%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EArchive%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
无评分
版本历史
最后更新:
‎03-19-2018 02:49 PM
更新人:
