undefined reference to `__pformatter'
已解决
跳至解决方案
2,695 次查看
Saikiran
Currently I am porting MQX4.1 project to MQX4.2 which is running on MK60FN1M0VLQ12 controller. we want to use UART for debug output application is building properly but at linking stage showing error ARM_GCC_Support/ewl/EWL_C/src/stdio/vsnprintf.c:58: undefined reference to `__pformatter' related to ewl library, please suggest possible solution for this issue.
Saikiran
1 解答
2,671 次查看
Saikiran
Hi @danielchen
Thanks for the Help, I tried the solution provided by you still the issue is not provided. found below ticket similar to my issue.
https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/How-to-use-printf-function-in-S32DS-fo...
changed linker settings flags and it worked issue resolved.
Saikiran.M
在原帖中查看解决方案
标记 (1)
2 回复数
2,681 次查看
danielchen
Hi @Saikiran
Please refer to below link:  "undefined reference to __pformatter"
https://community.nxp.com/t5/CodeWarrior-Development-Tools/error-quot-undefined-reference-to-pformat...
I hope it helps.
2,671 次查看
Saikiran
Hi @danielchen
Saikiran.M
标记 (1)
