multi-drop SWD
multi-drop SWD
jun1
Contributor V
Thank you for your help.
Does the KL17 series SWD support multi-drop SWD?
Thank you.
kerryzhou
Hi jun yamada,
   Thank you for your interest in NXP kinetis product, I would like to provide service for you.
   Unfortunately, KL17 swd can't support multi-drop, mainly can't use the SWD_CLK together.
  So, if you use multi-drop, you need to jump the SWD_CLK, make sure just one chip connect in SWD_CLK line.
Wish it helps you!
Kerry
kerryzhou
Hi jun yamada,
Wish it helps you!
Kerry
jun1
Contributor V
Thank you very much. OK.
