mbedtls- RSA 2048 Bit Key generation
swaminathanrath
I had downloaded the KSDK for FRDM-K82, tested the mbedtls selftest code which is available in the below path.
SDK_2.2_FRDM-K82F\boards\frdmk82f\demo_apps\mbedtls\mbedtls_selftest.
Question: Required help to generate rsa_genkey -2048 bits
Downloaded the attached rsa_genkey.htm from mbedtls and integrated in selftest.c which is attached for your reference
unfortunately the code is going to Hardfault when executing the function memset.
Thanks & regards,
Swaminathan.R
vicentegomez
Do you still have a problem with this, I am not sure if you get an internal support for this
Vicente Gomez
