lpi2c using LPI2C_MasterTransferNonBlocking for EEPROM
2,807件の閲覧回数
rs__zen
I'm trying to use EEPROM(24FC64) by using LPI2C_MasterTransferNonBlocking function.
I can write data to EEPROM, but I cannot to access Random Read(pls see attached).
How do you do a dummy write and subsequent read using LPI2C_MasterTransferNonBlocking?
Thank you.
3 返答(返信)
2,760件の閲覧回数
PabloAvalos
Hi @rs__zen
I would like to apologize for the delay. We are overloaded on the requests these days. I truly appreciate your patience.
Regarding your question, personally I would suggest you to use LPI2C_MasterTransferBlocking, because non-blocking function is going to read/write just one byte every time that it is being called and not the full message that you want to read/write on your EEPROM. It happened to me twice.
Also, can you please explain me what is your intention for doing a dummy write?
I will stay tuned to your answer, please let me know if you have more questions.
Thank you.
Sincerely,
Pablo Avalos.
2,750件の閲覧回数
rs__zen
Hi PabloAvalos.
Thank you for your answer.
Dummy write means that it is write command without write bytes.
I feel it could be done by setting up the following.
lpi2c_master_transfer_t masterXfer;
memset(&masterXfer, 0, sizeof(masterXfer));
uint8_t dummyBuf[1] = {0};
masterXfer.data = dummyBuf;
masterXfer.dataSize = 0;
So,I send dummy write command and read command,  I could random read access with EEPROM using LPI2C_MasterTransferNonBlocking.
I will ask again if problems arise.
Thank you.
Sincerely,
rs__zen
2,746件の閲覧回数
PabloAvalos
Hi @rs__zen
Thanks a lot for letting us know with your reply.
If you still require further help, please create a new post refering to this thread. We will be more than glad to help you.
Best Regards.
Pablo Avalos.
