kboot 2.0 porting FSL_FEATURE_FLASH_PFLASH_BLOCK_DATA_PATH_WIDTH
1,687 次查看
pem
i 'll working to port kboot to mk51dx128clh7.  i found the para in MKXX_features.h "FSL_FEATURE_FLASH_PFLASH_BLOCK_DATA_PATH_WIDTH (x)" . how to set the value x.
2 回复数
1,667 次查看
mjbcswitzerland
Specialist V
The open source uTasker project https://github.com/uTasker/uTasker-Kinetis contains ports for all Kinetis parts.
The operation only requires a subset of the specification since much is not practically used so that parameter will never be requested anyway.
Mark
1,677 次查看
jay_heng
This param is FTFx controller feature, you cannot set it manually. it should be provided by NXP
But this param is not used in kboot, so you don't need to worry about its value.
