kboot 2.0 porting FSL_FEATURE_FLASH_PFLASH_BLOCK_DATA_PATH_WIDTH
1,727件の閲覧回数
pem
i 'll working to port kboot to mk51dx128clh7.  i found the para in MKXX_features.h "FSL_FEATURE_FLASH_PFLASH_BLOCK_DATA_PATH_WIDTH (x)" . how to set the value x.
2 返答(返信)
1,707件の閲覧回数
mjbcswitzerland
Specialist V
The open source uTasker project https://github.com/uTasker/uTasker-Kinetis contains ports for all Kinetis parts.
The operation only requires a subset of the specification since much is not practically used so that parameter will never be requested anyway.
Mark
1,717件の閲覧回数
jay_heng
This param is FTFx controller feature, you cannot set it manually. it should be provided by NXP
But this param is not used in kboot, so you don't need to worry about its value.
